Cannot change transmission mode anymore
4620 10 2020-10-31
veiovis
Hello,
I have DJI FPV Goggles and a drone with an DJI AirUnit and one with a Caddx Vista.
My problem is that I cannot change the transmission mode anymore (I mean the option in the DJI FPV Goggles: Settings -> Transmission -> Preferences). I can see the current mode (low latency on one and high quality on the other). But it is grey and I cannot select the field to change the mode.
I have version 01.00.0600
Why cant I change the mode? Please help
2020-10-31
fans848f7190
Flight distance : 20669 ft
Do you have the quad powered up when you are trying to change the options?
2020-11-7
veiovis
Yes, otherwise the whole "transmission" submenu is disabled.
2020-11-8
Xviews
Flight distance : 229255 ft
which camera?
2020-11-8
veiovis
The one that come with DJI AirUnit and the one that comes with the caddx vista (not Nebula).
2020-11-8
bilgefpv
Turkey
Hi,
I'm having this issue with my setup too (nebulaPro) . Can't change the transmission settings 25mw and 25mbps only. Other than that I have unstable link quality. This is weird. I've done with my checklist again and again but still have the issue. Please help if any information possible.
2021-3-29
veiovis
For me, the problem was using the nebula camera. it doesnt support it.
2021-3-29
djiuser_2G33NieqGI2a
Belgium
Bilgefpv the problem you have is that you have to do the fcc hack to unlock the 50 mbps and up to 1200mw. You can just searh it on you tube.
2023-6-17
Belgium
bilgefpv Posted at 2021-3-29 06:00
Hi,
The problem you have is that you have to do the fcc hack to unlock the 50mbps and up to 1200mw
2023-6-17
Belgium
Hi,
2023-6-17
frommars
New Zealand
can you connect  DJI goggle racing edition to a fpv drone that has Caddx Vista Air Unit
2023-11-15
