Can you turn the Osmo Pocket 2 off while a 3rd party filter is on?
1552 8 2020-11-4
XY Plane
Can you turn the Osmo Pocket 2 off while a 3rd party filter/lens is on and so that the filter/lens wont collide with the anything?
2020-11-4
PenguinWhale
New Zealand
I tried with Freewell's ND1000 filter on and it didn't work. It collides as the camera rotates in
2020-11-4
DJI Stephen
Hello there XY Plane. Thank you for reaching out and for the inquiry. It would be best to remove all 3rd party accessories and other accessories on your DJI Pocket 2 before tuning on and off the said camera. These accessories might harm the said DJI camera on the process it wants to do. There is a possibility that these 3rd party accessories will be able work properly. However, since it's not yet optimized and tested by DJI we cannot guaranteed the stability of the said 3rd party accessory if it will work all the time with no issues and this might void the warranty of the said DJI product. Thank you.
2020-11-4
XY Plane
Well that’s just perfect. After removing the nd filter after every time I want to store the pocket 2, I finally dropped and broke one my nd filters after like the 30th time maybe having to remove it. Normally I would be upset for like 10 minutes and just order another one, but right now I’m in the middle of a trip and logged on just to post this
2020-12-11
djiuser_KlvpQC2UNHus
My osmo pocket 2 is facing forward when I close it with ND filter. Can I put the camera in is case facing forward ? Or it can create problem with the gimbal.
2021-1-27
TobiFromGermany
Flight distance : 45423 ft
djiuser_KlvpQC2UNHus Posted at 1-27 12:57
Hy there,
my pocket 2 is facing backward when I close it with ND filter and the filter collides. Is there a way to face it forward when turning off the pocket 2?
Thank you for your support.
2021-1-28
fansb26944ed
Flight distance : 555417 ft
Israel
My Pocket 2 is also facing forward with filters attached.
But, it recognizes filters where both magnets are oriented by same magnetic poles outwards. Any filter that have opposite magnetic poles orientation - is not recognised.
So, I have two filters packs from freewell and all filters from Landscape pack and one filter from BrightDay pack - are properly recognised. Three filters from BrightDay pack have opposite magnetic directions and not recognized properly.
I dont know who is response for this defect - not clear specification for manufacturers or bug in filters production, but it is clearly defect.
I would like to ask DJI to fix the bug in nearest FW update, if it possible.
2021-1-29
fansb26944ed
Israel
To be more clear - I call "opposite" magnetic poles for different magnets orientation on sides of same filter.
2021-1-29
Cients
Flight distance : 5537369 ft
Portugal
fansb26944ed Posted at 1-29 10:39
2021-1-29
