Pilot Disconnection
797 4 2015-6-26
ara9112003
Flight distance : 495869 ft
I'm having disconnection problems with the pilot app,even with the wifi turned off ,I tried with the original cable and is the same. I'm using a iPad mini 2.
Always is happening on the end of the battery like around 50%
Any suggestion?
2015-6-26
jmhirtle
Flight distance : 118845 ft
I just had the same thing happen for the first time after 20+ flights
2015-6-26
Spankybear
Flight distance : 685089 ft
What device?
2015-6-26
campatterson
Flight distance : 2014 ft
I had the same issue before I realized that the phone in my pocket had WiFi turned on and was causing issues. When I switched off Wifi on the phone, no more problems with disconnection except when there is a poor antenna orientation (should be perpendicular to direction to aircraft).
2015-7-2
dmwierz
Flight distance : 61427 ft
campatterson Posted at 2015-7-3 01:49
I had the same issue before I realized that the phone in my pocket had WiFi turned on and was causin ...
The OP said he had WiFi turned off...
2015-7-2
