RavenEye channel switched automatically.
2890 13 2020-11-7
MDoS24
Brazil
Hello,
I´m using a Canon EOS R5.
I turn on the gimble and the RavenEye.
I connect my iphone to the RavenEye Wifi.
Open the Ronin App for IOS.
The app says that the RavenEye its connected, opens and I can see the image but after 2/3 seconds the following error appear: RavenEye channel switched automatically. Reconnect to RavenEye Wi-fi to complete switching channel.
Then a message saying: RavenEye disconnected appears.
If I go back to the Wifi setting there is no longer a RavenEye WIFI option.
Am I doing something wrong? I´ve tested on the EOS R aswell.
2020-11-7
ogburrigmail.com
Switzerland
Same problem here with a BMPCC6K
Firmware bug or lemons...
2020-11-7
fansb5a3e6c9
New Zealand
Same here, raveneye disconnect after 3 second
2020-11-10
MDoS24
Brazil
Up.
As you can see there are a lot of people with the same problem.
2020-11-10
ogburrigmail.com
Switzerland
yes, but there is no help from the support
2020-11-10
MDoS24
Brazil
Support? Anyone?
2020-11-13
CRACVISION
Flight distance : 100912 ft
Puerto Rico
I spent one entire week back and forward with DJI working on this issue, sending videos of the problem, sending testing results with 4 different mobil device (iOS Devices), reseting the unit, etc. I requested a unit replacement to B&H and today I received the replacement, I started all the process again and still having the same problem. At the moment I opened the service request with DJI nobody was complaining about this issue and DJI said they have not received this issue reported before. I’m wondering what they going to say now that I’m not alone on this. I imaging the majority of you guys like me bought this product because the raveneye and it is very frustrating that this is the only part that not works!
2020-11-14
Mad_Angler1
Flight distance : 2741657 ft
See this post https://forum.dji.com/forum.php?mod=viewthread&tid=228967
2020-11-14
ogb
Switzerland
CRACVISION Posted at 11-14 02:36
They don't give a ...
2020-11-14
djiuser010101
Malta
I hope this issue gets resolved soon. I am currently stuck with the blue LED and 3 white LEDs blinking. Can do nothing about it, and I cannot even see the RavenEye WiFi on my Huawei phone. I can see the RavenEye WiFi on my iPad, but it does not connect successfully.
2020-11-18
MDoS24
Brazil
This whole situation is very sad. Such a bad support for such good products.
2020-11-18
MDoS24
Brazil
Upupupupuupup
2020-12-4
JotEff
Flight distance : 86916 ft
Anything new?
I´ve the same problem. On the first use everything worked for a few seconds. Then the wifi channel changed and since then just my Surface is able to see the Raveneye-Network. But thats of no use.
Is there anything i can do? Reset the Raveneye? Connect it with a dji software to my Surface?
2020-12-28
Giulian76
Flight distance : 1886608 ft
2021-1-4
