Indio
Flight distance : 303373 ft
Austria
paul pan wrote (i think will come to the RS-2 also):
RSC2 Beta
What’s New?
• Added Orbit Follow mode.
• Added manual setting for focus endpoints for DJI Ronin Focus Motor, where users can set a controllable range between Point A to Point B manually.
• Added Deep Sleep mode to extend battery power. Press the gimbal power button twice to enter sleep mode, and the gimbal will automatically enter Deep Sleep mode after 10 minutes if no interaction has happened with the gimbal. The touchscreen will be set to its lowest brightness, and the RSA accessory expansion port will power off. Repeat to exit Deep Sleep mode.
• Added front dial control over camera parameters, shutter speed, gimbal tilt/pan movements. Also added adjustable front dial smoothness and direction reversal.
• Added shutter/autofocus control for Z CAM E2、Z CAM E2-F6、Z CAM E2-F8、Z CAM E2-M4、Z CAM E2-S6
• Optimized roll axes algorithm for large angle tracking in Horizontal, Portrait, and FPV modes, preventing the gimbal from getting stuck during tracking at specific angles.
• Fixed issues: The built-in screen flashes when the gimbal motor is stuck during rotation
• Fixed issues: calculation error of customized parameters in Panorama mode.
• Fixed issues: when using Z CAM with manual lenses, the gimbal axes failed to stabilize the camera.
Notes
• Make sure that the DJI Ronin app is the latest version when updating the firmware.
• Update the firmware using the DJI Ronin app by connecting the DJI RSC 2 via Bluetooth. Update the firmware of RavenEye transmission module separately by connecting it with DJI Ronin app via Wi-Fi Do not disconnect the DJI Ronin app and DJI RSC 2 during the update. Do not disconnect the DJI Ronin app and DJI RSC 2 during the update.
• If DJI RSC2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
• If the firmware update fails, restart DJI RSC2 and retry.
