Mini 2 Battery firmware update?
8931 10 2020-11-11
Juke
Flight distance : 207182 ft
Finland
Just got my Mini 2 today. (And updated DJI Assistant 2 to DJI Assistant 2 (Consumer Drones Series).)
I updated the firmware of RC with DJI Assistant and firmware of Mini 2 with DJI Fly app. But I don't know how to upgrade the firmware of the battery or even verify it. When I connect M2 to my laptop DJI Assistant 2 shows only image attached.
Don't understand why DJI Assistant 2 shows firmware version and allowed upgrade of the RC but not the M2 itself. Any suggestions?
Message
Message
2020-11-11
TDZHDTV
Flight distance : 2068550 ft
Just boot up the Mini and controller, don’t go to camera view, stay on the start screen, your battery upgraded option will be visible.  If you have 3 batteries likely the battery in the drone was already updated with AC firmware update.  Always good practice to pop each battery in after a firmware update
2020-11-11
JohnLietzke
Flight distance : 3125968 ft
Are you using Windows or MacOS?
I have problems with DJI Assistant 2 being in the original directory it was installed in initially.  This was on MacOS and after the DJI Assistant 2 application was installed in the Applications folder a terminal window opened and requested a password to install additional code.  I then moved the DJI Assistant 2 to a different folder and was not able to use the functions of the app.
I reinstalled the DJI Assistant 2 and left it in the Applications folder and it worked properly.  This may also be relevant to windows but I can not test it.
2020-11-11
Juke
Finland
TDZHDTV Posted at 11-11 09:08
Ok,thanks,  didn't select GO FLY but nothing happened. It's fine if battery firmware was upgraded same time as M2 firmware was. But I would like to verify it.
2020-11-11
Juke
Finland
JohnLietzke Posted at 11-11 09:14
Thanks for your advice. I'm using Windows and I re-installed DJI Assistant 2 but it's the same.
2020-11-11
TDZHDTV
I’m not able to see the drone using Assistant, it recognises the remote tho
2020-11-11
Juke
Finland
TDZHDTV Posted at 11-11 09:37
Me too, not. If I remember right with my Mavic Mini, Assistant recognized drone too.
2020-11-11
Juke
Finland
Juke Posted at 11-11 09:45
Ok, it's the broken DJI Assistant. Same problem in another thread with Mac: https://forum.dji.com/forum.php?mod=viewthread&tid=228831
Hope it gets fixed soon, DJI?
2020-11-11
A J
Flight distance : 13926112 ft
Assistant 2 for Consumer is presently broke!
2020-11-11
correlatif
Flight distance : 25466 ft
Hello,
I have exactly the same issue. Only "log export" appear in the menu of DJI assistant. Any news about this ?
2020-12-19
djiuser_NMEGPFEC1Ic8
Flight distance : 9616 ft
Juke Posted at 11-11 09:28
Not sure if you can verify the battery firmware itself was updated. When I got mine with three batteries, The one in the drone was already updated but the other two showed they needed updating and I did that....all work fine.
2020-12-19
