Charging Raveneye
21821 17 2020-11-16
usko
Does anyone know if you can charge the Raveneye by itself, or can it only be charged while connected to the RS2? I'd love to charge it up separately before a shoot to save the Ronin battery, but when I try plugging it into a charger by itself nothing happens. If I turn it on while connected to a charger, it does not indicate charging, and the battery level drops.
Any trick to getting that to happen?
2020-11-16
DJI Wanda
Hello, you can charge the Raveneye by using the USB-C cable (40cm), and the Chargers which have a 5V/2A output will be work.
2020-11-17
usko
DJI Wanda Posted at 11-17 03:48
That's what I thought too... but nothing happened. There was no indication of charging and I left it on for quite a while and no charge. Does it have to be turned on? I tried that too, but not as long as it seemed to be draining the battery.
2020-11-17
usko
Well, derp. I was plugging in the power on the wrong end! Works just fine now!
2020-11-17
DJI Wanda
usko Posted at 11-17 18:33
Hello, we are glad to see the Raveneye works. You can also refer the latest tutorial for the connection, hope it helps.
Thanks.
2020-11-18
bikoo
Flight distance : 1534987 ft
United Arab Emirates
How to disable the charging from the RSC while it's connected to the RSC?
2020-11-20
TaylorVision
What charger and cable did you use?  I have an iPhone 5v 2A charger with USB.
2020-12-26
TaylorVision
Crazy how DJI can't support Ronin LIVE chat.  My Raven Eye hasn't gotten past one blinking light while charging on the Ronin SC2.  6 hours now.
2020-12-26
usko
Make sure you're plugged into the correct end. That's the mistake I made. They both use the USB-C, but one end is for charging, and the other is for connecting to the gimbal. Easy mistake to make!
2020-12-26
usko
TaylorVision Posted at 12-26 07:57
I used a standard USB that I think came with a Samsung phone. Pretty much any USB charger should work.
2020-12-26
illuminatedRS
Is there a way to power it off of USB while it's on and in use?  Would be nice to get more than a couple of hours out of it? Maybe off the same battery that the camera is using ...say off the v-mount's p-tap -> usb-c for example.?  - The fxlion nano batteries have usb-a usb-c usb-micro and p-tap out.
2021-7-10
doctoraxis
Flight distance : 19150 ft
South Korea
Hi, RavenEye has two USB-C type shaped ports(another one RSS). Use thunder sign(charging sign) USB-C type port for charging. This is opposite side of HDMI port and RSS port. Do not use RSS UBS-C port.
2021-8-25
Vitor G.D.
Flight distance : 70499 ft
Brazil
And I'm trying to charge mine while in use with the rsc 2. The connection is fine, but it doens't charge.
2022-9-28
fans2ba81e0d
Flight distance : 217792 ft
TaylorVision Posted at 2020-12-26 08:00
Did you ever figure this out?
I just bought a RavenEye and having this exact problem.
Left on charge overnight. One blinking light at the start. It chart charge at all.
I’m using the right USB C Port. The one with the lightning next to it.
It’s incredibly frustrating.
Edit: figured it out. You have to turn on the device and leave it on before charging. Once left on and plugged in, I got 40% charge in 30min. One thing I've also noticed is that you it stops charging when my phone disconnects from the Raveneye, so for now i have to leave my phone connected.
2023-7-28
NANI WISHWA
India
Raveneye getting overheated. How to stop it from overheating
1-1 21:10
Raphaël Casassus
DJI Wanda Posted at 2020-11-17 03:48
Can I use a charger who has a 5V/1A output ?
1-21 03:01
DJI Wanda
Raphaël Casassus Posted at 1-21 03:01
Hello, there. Sorry for the late response. It is recommended to use a 5 V 2 A charger to get the optimal charging performance.
4-18 04:16
