Wireless connection problem solved for me
6721 20 2020-11-21
FrodeT
Norway
Finally it works and I got to connect to Osmo Pocket 2!
The wireless connection worked fine with the Huaway Mate and Ipone 8, but not the HTC U11.
HTC U11 works on 5 Ghz network, but not togheter with Osmo Pocket og Pocket 2.
With the latest firmware it looks like 5Ghz networks is default enabled, but you can change it to 2,4 network.
Changing Osmo Pocket to use 2,4Ghz network and it works.
Connect your phone to Pocket 2 with USB and under General setting you can change it to 2,4Ghz.
2 Ghz helps for my phone on Osmo Pocket and Osmo Pocket 2
2020-11-21
DowntownRDB
Flight distance : 1722 ft
Glad you were able to solve your wireless connection.
2020-11-21
DJI Stephen
Hello there FrodeT. I am sorry for the trouble this caused before on your DJI Pocket 2 and for sharing these information and these process on how you have fixed / resolved the said issue. This thread will be a very big help to our fellow DJI Members who are facing the same issue. Have a safe and a happy filming always.
2020-11-22
A J
Flight distance : 13926112 ft
Glad you managed to fix the issue
2020-11-23
playr
Poland
WOULD be great IF there was an option to change this setting. I wrote about this issue few weeks ago, just after the release. I suppose Your screenshot comes from first OP menu?
2020-11-24
FrodeT
Norway
playr Posted at 11-24 09:35
WOULD be great IF there was an option to change this setting. I wrote about this issue few weeks ago, just after the release. I suppose Your screenshot comes from first OP menu?[view_image]
No my screen shot is from the latest Mimo with pocket 2
I connected the pocket 2 to the phone with the USB and navigated to General settings.
There I can change it to. AUTO 5 GHZ or 2,4ghz
2020-11-24
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
Latest android DJI Mimo supports 5g 2.4g selection, solving the issue some android phones do not support or limited support for 5.8Ghz.
2020-11-24
heightoffield
Flight distance : 2670423 ft
Hungary
this solved my problem too! Thanks!
2020-11-26
Blériot53
Flight distance : 6188465 ft
I tried this and it has no effect whatsoever. Still get the same Connection Failed message.
2020-12-28
Norwegian Airlord
Flight distance : 854951 ft
Norway
THANKS!!! this solved my issues with Huawei mate 10 pro
2021-3-21
GawainNg
This unfortunately doesn't work for the Google Pixel 4a. Tested on all frequencies (Auto, 2.4Ghz and 5.8Ghz).
2021-4-10
HGDC84
Finland
Blériot53 Posted at 2020-12-28 02:58
What phone or tablet are you attempting to use? Is it on the DJI's official list (https://www.dji.com/fi/downloads/djiapp/dji-mimo) or on the lists gathered by fellow DJI users (see https://forum.dji.com/forum.php?mod=viewthread&tid=235190 for phones or https://forum.dji.com/forum.php?mod=viewthread&tid=237518 for tablets) ?
Also, check out the version of DJI Mimo installed. Not all versions of Mimo support Pocket 2.
Hopefully your problem gets solved.
2021-4-10
HGDC84
Finland
Also, have you downloaded the Mimo app from their own website or from the Google Play Store? According to some sources, the Play Store version is outdated and now the app should be downloaded from Mimo's own website. Also, before installing the version from the Mimo website, you may have to uninstall the version installed from Google Play Store.
2021-5-13
Blellow
Flight distance : 1311056 ft
Thank you.  This was killing me when trying to quickly change between the osmo n the p2.
2021-5-13
djiuser_WmNeXxTXxOPh
GawainNg Posted at 4-10 02:08
So you were NEVER able to connect google pixel 4a to the pocket 2 via WIFI ( ? ? ? ? ]
2021-8-16
djiuser_O57MxPaEapcp
Seychelles
I have the same issue. I can detect the wifi, but I cannot connect the pocket2 via DJI MIMO. My cellphone is Redme K30 ultra.both the auto, 2.4, 5.8
2021-9-12
Debugger
Flight distance : 4865846 ft
Greece
THANKS!!! this solved my issues with Huawei P20 Lite
2021-12-24
Phanguin
I would like to also add on a wireless issue I had. After restarting both my phone and devices multiple times and reinstalling the mimo app. I found out that all I needed to do was disable the VPN on my phone to be able to connect to my OP2. So make sure your VPN app is deactivated.
2021-12-26
HGDC84
Finland
Phanguin Posted at 12-26 14:52
That's a great tip for troubleshooting, added that to my device compatibility/troubleshooting threads. Thanks and have a great new year!
2021-12-30
HGDC84
Finland
playr Posted at 2020-11-24 09:35
You could see if the troubleshooting tip #2 on my phone compatibility/troubleshooting thread could work (installing an earlier version and changing the frequency setting there, then updating the app). The link is mentioned on my earlier messages on this thread.
2021-12-30
djiuser_ZxnWw1c5pP1G
Guatemala
Any solution for Xiomi new phones it simple not detect the pocket 2 network
2022-10-19
