djiuser_O72GPOySgfJv
Flight distance : 2336 ft
DJI Stephen Posted at 11-25 01:30
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Can you please fly your DJI Mavic Air 2 to a different location with less interference to see if the issue will still persist? The said DJI drone might have picked up magnetic interference on the ground, and you took off from close to a buildings with rebar concrete metal objects on it. In addition please make sure that the antennas are pointed toward the aircraft for optimal transmission. Thank you.
[view_image]
Antennas were pointed direct and I can’t even go more than 4000 feet without connection drop, the other week I had the drone hovering and it swept to the left I moved it back into position then it did it again so I didn’t wana lose or crash it so I landed and turned it off, I live in a country side type of area there would not be any interference to that degree |
