New DJI RSC 2 Firmware Released (25/11/2020)
14014 28 2020-11-25
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2020.11.25
  • Firmware: v01.01.00.10
  • RavenEye Firmware: v01.01.00.10
  • DJI Ronin App iOS: v1.4.4
  • DJI Ronin App Android: v1.4.4
  • User Manual: v1.0
What’s New?
  • Added video recording, camera settings, autofocus, and focus pull support for Sony A7S III and A7C cameras with supported Sony E mount lenses using a Multi-Camera Control Cable (USB-C). To use autofocus on the Sony A7S III and A7C cameras, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Nikon Z6 II and Z7 II cameras with supported Nikkor lenses using a Multi-Camera Control Cable (USB-C). To use autofocus on the Nikon Z6 II and Z7 II, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Nikon D500 cameras with supported Nikkor lens using a Multi-Camera Control Cable (Micro-USB). To use autofocus on the Nikon D500, press halfway down on the camera control button of the gimbal.
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Panasonic Lumix S5 cameras with supported L-mount lens using a Multi-Camera Control Cable (USB-C). To use autofocus on the Panasonic Lumix S5, press halfway down on the camera control button of the gimbal.
  • Added video recording, camera settings, autofocus, and focus pull support for Panasonic Lumix BGH1 cameras with supported Micro 4/3 mount lenses using a Multi-Camera Control Cable (USB-C). To use autofocus on the Panasonic Lumix BGH1, press halfway down on the camera control button of the gimbal.
  • Added aperture settings for Olympus E-M1 II cameras.
  • Added ability to check the battery level while the gimbal is powered off by pressing the power button once.
  • Added ability to auto calibrate and delete endpoints for the focus motor. Enter advanced settings and scroll through to select the endpoint settings for the focus motor.
  • Added ability to access camera settings for DJI RavenEye Image Transmission System by connecting the camera using a camera control cable.
  • Optimized power management for DJI RavenEye Image Transmission System, increasing the runtime of both the transmission system and gimbal.
  • Optimized the DJI RavenEye Image Transmission System connection experience by removing the default password 12345678. After linking via the system’s Wi-Fi, a password must be set in the DJI Ronin app. The password must be 8 characters long and consist of letters and numbers.
  • Optimized the gimbal transition when switching to Briefcase mode.
  • Fixed occasional issue: when using with the BMPCC 4K camera, the gimbal axes failed to stabilize when changing the frame rate during recording.
  • Fixed issues: Nikon Z5, D780, and D5 cameras could not display the liveview on a camera, mobile device, or gimbal after connecting to DJI RavenEye Image Transmission System.
  • Fixed occasional issue: when using the Panasonic GH5, GH5S, S1, S1H, and G9, the gimbal failed to control the camera after hot plugging the camera control cable.
  • Fixed issue: when using the Olympus E-M1 II camera, the camera restarted repeatedly and was unable take photos in AF mode after hot plugging the camera control cable.
  • Fixed issue: unable to take photos in AF mode by pressing and holding the camera control button when using the Sigma FP camera.
Notes:
  • Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • Update the firmware using the DJI Ronin app by connecting the DJI RSC 2 via Bluetooth. Do not disconnect the DJI Ronin app and DJI RSC 2 during the update process.
  • Update the firmware for the DJI RavenEye Image Transmission System using the DJI Ronin app by connecting the RavenEye via Wi-Fi. Do not disconnect the DJI Ronin app and DJI RavenEye Image Transmission System during the update process.
  • If DJI RSC 2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
  • If the firmware update fails, restart DJI RSC 2 and retry.
2020-11-25
RocDoc
United Arab Emirates
Thank you for releasing this update.
2020-11-25
saviour
Flight distance : 604203 ft
What about the Sony APSC cameras like  the A6400? Will the Cable work with them now, too?
2020-11-25
djiuser010101
Malta
saviour Posted at 11-25 13:18
I wish they can get this to work alongside the a6500, too. It seems like it only works through USB C.
2020-11-25
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2020-11-26
bastosboi
Flight distance : 232300 ft
Thanks for quick support of Nikon Z6 II.
I have installed the new firmware on my RSC2 and the update was successful, was confirmed by the Ronin app. Also the display on the gimbal shows the latest version has been installed.
However, the announced Nikon Z6 II support does not work for me.
- My Z6 II does not get recognized by the gimbal.
- The camera icon does not show up on the gimbal display.
- None of the RSC2 controls work (record button, index finger wheel etc.)
I have used the supplied DJI USB-C to USB-C cable for connection.
Before the firmware update, at least the camera got recognized. Now, nothing at all.
I have restarted both the Nikon Z6II and the DJI RSC2 gimbal. The iOS app I've restarted also.
As lens I'm using Nikkor Z 24-70 f2.8 S.
Did anybody get the RSC2 to control Nikon Z6 II? Anything I'm doing wrong?
2020-11-26
RocDoc
I am using a Nikon Z6II with a Nikkor 24-70 f.28 lens.
I have updated the firmware on my gimbal. I turned off the gimbal and the smartphone Ronin application.
I am using a Samsung S7 Android phone on the phone mount. I also am using a Samsung Note20 for remote.
When I restarted gimbal and application the first time, the smartphone application hung while connecting to my gimbal. I turned gimbal and smartphone application off again.
I restarted the mobile phone. I turned on the gimbal first, and waited for the menu to show. Then I turned on the smartphone and started the ronin application.
The application connected to the gimbal in less than 5 seconds.
The gimbal now works in every respect. Camera movement, start record, stop record, snapshot. All gimbal menu options that I have tried work correctly.
I now have to connect raveneye and focus motor (for zoom) and test those.
I am pleased with the firmware update, which has fixed the problems I had with the RSC2 gimbal.
Thank you, DJI
2020-11-26
bastosboi
RocDoc Posted at 11-26 19:27
Thanks RocDoc for your detailed explanation.
Unfortunately, camera connection to Z6 II still does not work for me.
May I ask which firmware you are running on the Z6 II? Have you already updated to v1.01 which Nikon released last week?
I am running Nikon firmware v1.01 and the DJI app checklist shows an exclamation mark for Camera Control Cable. It is the supplied cable, which was working fine before. Have also tried another data-capable USB-C cable, same issue.
2020-11-26
bastosboi
Update: I have also tried to connect my other camera, Nikon Z50. I have the same problem. The RSC2 does not show camera icon and camera cannot be controlled. So it seems to be an issue with my RSC2, not with the Nikon Z6 II or Z50.
I will contact DJI support.
2020-11-26
Roc Doc
My gimbal firmware is 01.01.00.10
My Nikon Z6II camera body firmware is 1.01
I hope that helps.
2020-11-27
djiuser_Bg5dx4taDBLx
Any ETA on a firmware update for the RSC 2/Raveneye to work with the new Fujifilm X-S10?  I have all three of you need hands-on testing. Unfortunately the X-T4/USB-C method doesn’t work with the X-S10 (the X-S10 just reboots repeatedly while connected to the RSC 2 via USB-C) and the DJI Fuji cable uses a 2.5mm plug while the X-S10 has a 3.5mm remote jack.
2020-11-29
fans9197fb35
Flight distance : 3471988 ft
Great news, but still I can't control the aperture on the A7SIII. Why ? Thanks !
2020-11-29
fans7a7a3802
It's not in the devices compatibility list, but I want to advice that the RSC2 gimbal can fits the camcorder Sony FDR AX700 (even with the longer battery NP FV100A) without any issue and controls both the start/stop recording with its dedicated switch and the zoom using the front wheel. I'm very satisfied and I'm pleased to share it.
2020-12-2
Kanaye Shogun
Flight distance : 335062 ft
Croatia
Hello.
I can't get my Sony A7sIII to work with RSC 2 with USB type C that was in the box. I have the latest Firmware on RSC 2 ( v01.01.00.10)  and my Sony A7SIII. When i connect the USB C cable I get black screen on Sony with USB MODE - MTP that i cant get rid off. There is no option in Sony to select PC remote ( it is in Auto ). If i use cable for Sony everything works but I cant set front wheel for autofocus, ISO, aperture ect.
How can i fix this ?
Thank you!
2020-12-3
Kanaye Shogun
Croatia
Kanaye Shogun Posted at 12-3 07:34
Hello.
I found the solution myself. Sony changed menus on A7sIII ( from A7III ) so PC remote option is under TRANSFER/REMOTE - PC REMOTE FUNCTION and not under USB Connection and you have to turn it On.  You can leave the post if it helps someone else too.
2020-12-3
David Fogle
Flight distance : 23642 ft
The z6ii was added to this release, but raveneye seems to be slightly broken for it. If I use just the gimbal with the camera, focus and shutter work perfectly. When I add in the RavenEye, I can no longer use the camera's focus system, and the record button on the gimbal is functionless. I can however press the record button in the Ronin App and it triggers the record on the camera.
2020-12-4
djiuser_oWPlTg437P1Y
Fuji xt30 usb-c suport?
2020-12-4
2020-12-4
fanse69caee5
Flight distance : 177438 ft
2020-12-10
ilcentaurorosso
Using Panasonic G9, the gimbal failed to control the camera after hot plugging the camera control cable. This issue has not be fixed (or the usb-c port is broken)
I am not able to control start/stop recording, focus, aperture, ISO... anything!.
2020-12-13
Martinlee94
Malaysia
Hi guys i need some help here , I having problem with Raven eye with my Sony A7iii . My phone can have visual of my camera when i sleep my RSC2 but when i wake the RSC2 the screen just went black , Is anyone know if this is some sort of camera settings issue or my set-up issue ? Many thanks
2020-12-16
djiuser_soMCA00bax64
Any chance of support for the 3D focus module that you just gave to the rs2?
2020-12-17
gatesgodman
Cameroon
WhatsApp: + 195.46.41–82.38 Buy Xanax bars , Lean syrup , Oxycodone , Adderall , Percocet , Methadone , Ecstasy , Lsd and acid , Actavis Promethazine Cough Syrup , Viagra , Vyvanse , Klonopin , Fentanyl , Rohypnol (Roofies) , Ketamine , Hydrocodone 10/325, MDMA (molly) crystal and pill form , Crack Cocaine , Heroin (white, brown and tar) E-mail: danny@doctor. com  Weed , Marijuana , Cannabis buy in Switzerland , Germany , Spain , Italy , Strawberry , Sour Diesel , Jack Herer , Durban Poison , Haze, Pineapple Express , Blue Dream , Purple Haze , AK-47 , Grapefruit , White widow , OG Kush , Purple Kush , Black weed , CBD Oil , Hemp oil , Moonrock for sale in Switzerland , Germany , Spain , Italy , E-mail: danny@doctor. com Nembutal  Pentobarbital  Sodium online  WhatsApp: + 195.46.41–82.38
2020-12-21
ralphp
Flight distance : 741 ft
New Caledonia
keep up the good work because RSC 2 still doesn't work with my SONY A7c : no capture (so no creative function) et RavenEye doesn't work too (no ActiveTrack...).
2020-12-22
djiuser_ltvDPyCbXx6D
Flight distance : 551381 ft
Bangladesh
After install this new firmware I see my aircraft lost connection within 30 sec when I start takeoff. After lost the connection the RTH activated automatically. When RTH begin and the aircraft connect again automatically.
So someone please advise me to resolve this issue.
2020-12-22
fans16ef778f
Peru
cant take photos using sony Alpha 7, autofocus is good and also recording.
2020-12-25
djiuser_9fg8qiMCNx0i
Hey Y'all!
I noticed a bug with the latest firmware 2020.11.25 Firmware: v01.01.00.10
Bug: If I connect my Panasonic Lumix GH5 to the gimbal using the USB-C and change a setting in the "creative video mode" menu from the menu button, the gimbal will no longer be able to pull focus while the camera is recording.
Summary:
I'm using a Panasonic Lumix GH5 with a Panasonic LUMIX G Leica DG SUMMILUX Lens, 15MM, F1.7 ASPH lens. Using the USB-C and PC Tether mode, the Ronin RSC-2 is able to pull focus of the Panasonic in both photo and video modes. HOWEVER, if I am using "creative video mode" and use the menu button > creative video > exposure mode > and select P, A, S, or M; the ronin will no longer be able to pull focus while recording. The record functionality button still works with the gimbal, and when not recording the gimbal can still pull focus. BUT as soon as the camera begins recording, it no longer pulls focus.
Turning the camera and gimbal off and on again, does not fix this issue.
Reverting the setting back to it's original setting, does not fix this issue.
Updating the firmware on the gimbal, does not fix this issue.
Changing any of the other "creative video mode" settings, does not trigger this bug.
The only solution that I have found, is by resetting the camera back to it's factory settings. This will then allow for the gimbal to pull focus when recording.
ONE MORE THING, just to make things even more confusing. If I'm in "creative video mode" and use the LCD panel to adjust the exposure mode to P, A, S, or M, this will not cause the gimbal to stop being able to pull focus. The gimbal will continue to function normally. HOWEVER, if I go to the menu button, and go through the above steps, it will trigger the bug, and the gimbal will no longer be able to pull focus.
Hopefully all this info, will help any other Panasonic Lumix GH5 users, and the DJI development team. Let me know if you have any questions.
Thanks!
2020-12-27
djiuser_Gg9lSkK1ccU3
Poland
Hello!
Everything except taking pictures (in panorama mode) works fine.
I have Sony A6300 - newest firmware.
Have a nice day!
2021-1-20
crabby.visuals
Hi guys,
in case someone ends up here because they can't take photos with a Sony a6300 or any other Sony camera.
It took me 1 week to find out, that DJI is shipping a special USB-C to Sony cable
This was the first post i found, when i googled for the problem.
So I hope this helps anyone.
Have a nice one
2021-3-27
