david.p.mann
Flight distance : 18669501 ft
I purchased a Microraptor Pro Case for my Phantom 3 Pro from an Amazon.com vendor several weeks ago, and it has met all my needs. I did have to use an Exacto knife to carefully increase the size of the four foam cutout openings for the prop arms to accommodate the SummitLink Snap-on Prop Guard connectors on my bird. This is a very well-made case that has several cutomizing options for the cavity on the left-hand side. I opted to totally open this cavity up, but left a stair-step piece of foam at its bottom that provides a somewhat deeper hole for my Apple iPad Air 2, Apple iPad Mini 3 and a sun hood for the iPad Mini, and a slightly shallower cavity at the far left that neatly holds the four snap-on prop guards. I can also lay a larger sun hood for the iPad Air 2 on top of the Phantom 3 and still close the lid easily.
As shown in the photos below, Microraptor Pro Case can hold: Phantom 3 with gimbal guard and one battery installed, the Remote Controller, 8 props (four loose at bottom of front cavity with prop bag laying on top of them holding another four unused props), Accessory box, PolarPro ND Filters, RC harness, iPad Air 2, iPad Mini 3, sun hoods for both mobile devices, four snap-on prop guards, four additional spare batteries (five if you also use the cavity that I used for the P3 accessory box). The cavity in the back, where I store the ND Filter bags and RC harness, can also accommodate the DJI P3 battery charger and AC power cord. Note: the case is designed to allow you to store the P3 with all 4 props mounted (without putting damaging pressure on the props), but I opt to take the props off before storing the P3 in the case. The rectangular silver box in the right rear contains dessicant beads for absorbing moisture from the box when in storage mode with the lid closed. The dessicant can be regenerated by placing the tin in an oven at 350F for a few hours.
