Flying my PH3...last few times I've had it out...the live signal on my Iphone6 has been spotty and not fluid. Hard to see what I'm shooting as the signal seems to get hung or delayed. Reminds me of my TV signal (DISH Satellite) when a storm blows in...signal goes jerky and pixilated before losing it. Any idea why this might be? Was not like it first few times I flew. Wonder if I hit something in learning the DJI Pilo ap?
Hi,
What is your FW version? When you notice the spotty live feed, were you recording? Also, will the lag happen right after the take off, or when you hit record? Any pattern?
Turn down the video bit-rate in the settings. Not a real problem fixer, but it works for now.
On Android there is a slider at the bottom of the "Image Transmission Settings" called "Image Transmission Quality". Turn it down and see if that helps.
It is a stored setting and it shows the lowest (and not what I have set) value when I don't have anything on. I bet it is an EEPROM setting on the drone.
So yes, turn everything on first. Then you should be able to change it and it should stick.
