RSC 2 not working with Sony A7SIII with USB - C
8409 3 2020-12-3
Kanaye Shogun
Flight distance : 335062 ft
Croatia
Hello.
I can't get my Sony A7sIII to work with RSC 2 with USB type C that was in the box. I have the latest Firmware on RSC 2 ( v01.01.00.10)  and my Sony A7SIII. When i connect the USB C cable I get black screen on Sony with USB MODE - MTP that i cant get rid off. There is no option in Sony to select PC remote ( it is in Auto ). If i use cable for Sony everything works but I cant set front wheel for autofocus, ISO, aperture ect.
How can i fix this ?
Thank you!
2020-12-3
Kanaye Shogun
Croatia
I found the solution myself. Sony changed menus ( from A7III ) so PC remote option is under TRANSFER/REMOTE - PC REMOTE FUNCTION and not under USB Connection and you have to turn it On.  You can leave the post if it helps someone else too.
2020-12-3
Cayton828
Flight distance : 2358383 ft
Kanaye Shogun Posted at 2020-12-3 09:59
If there's any way you could give me a call I would really appreciate it. I have tried everything possible and cannot get my monitor to work with this gimbal. 828-226-7140. Thanks a lot
2022-4-8
Geziuss
Suriname
i wanna thank you for posting this comment... i've been searching the web for 3 days now and your comment is the only thing that actually helped me with my problem
2022-9-14
