Firmware old?
674 7 2020-12-5
bernardren07
Flight distance : 48504 ft
Singapore
Hi. When i want to update latest firmware should be v01.00.0670 but show old v01.00.0640? software dji assistant 2 for mavic version: v2.0.14.
old
old
2020-12-5
kyalami
Flight distance : 17352513 ft
Sweden
Just did a refresh and still got v01.00.0640 which is the same as I had. Where did you see that there was a new version 01.00.0670?
2020-12-5
bernardren07
Singapore
kyalami Posted at 12-5 10:33
I realised that remote controller only 0640. aircraft i just found that 0670 inside. Can working remote 0640 + aircraft 0670??
2020-12-5
kyalami
Sweden
bernardren07 Posted at 12-5 10:50
Yes, that is what I have in my set up and it is working fine for a bout the 3 month that I have own the gear.
2020-12-5
DJI Gamora
Hi, bernardren07. This is normal and the remote should remain on v01.00.0640 as its latest firmware version while the aircraft is on v01.00.0670.
2020-12-6
bernardren07
Singapore
kyalami Posted at 12-5 11:23
ok thank you so much. when i free then update firmware
2020-12-6
bernardren07
Singapore
DJI Gamora Posted at 12-6 00:22
ok thank you alot.
2020-12-6
DJI Gamora
You're most welcome. Should you have further concerns, please let us know.
2020-12-6
