Ingo Sundowner
Flight distance : 914012 ft
jonny007 Posted at 12-7 03:58
Active track is unfavorable if other objects come into focus during the tracking or if the selected object has too little contrast to the surroundings. Try the same in exactly the same place by selecting the follow mode. Assuming good satellite reception, otherwise the trajectory in follow mode can be a bit choppy from time to time *). Do not forget to click "Set from Aircraft Position" in the settings before starting after you have flown the mini into the position from which it should follow. Otherwise perhaps it flies first to the starting point and thus possibly into obstacles.
*) The more satellites are received and the further away the drone is from the RC the better it is
Valuable info, thank you very much!!! |
