Ronin S long charging
2609 3 2020-12-8
djiuser_fbcGXT2JiEls
Hi I’ve just bought the ronin s and am charging for the first time but it has be on for at least 6 hours now.
I’m very concerned as the instructions say only 2 hour charging time.
The green bar began at one and is now flashing 4, 6 hours later.
Thanks
2020-12-8
DJI Susan
Hi there, may I know the specs of the charging adapter you are using? Ronin-S supports chargers with a power up to 24W, the fast charging heads that are available on the market and meet the QC standard can also be used for charging. The charging time varies depending on the power of the charger. If you are using the 5V/2A charging adapter, the charging may take 5 hours.
2020-12-9
DJI Susan Posted at 12-9 00:46
Hey! I’m just using a standard Apple plug (presumably 24w) thankfully it did charge in the end but had to leave it overnight after 6hrs
Thanks
Josh
2020-12-12
DJI Susan
djiuser_fbcGXT2JiEls Posted at 12-12 14:41
Thanks
Hi Josh, thank you for getting back, please test the unit and see if all is normal. If there is a further issue, please feel free to let me know.
2020-12-15
