First Pano with the Pocket 2
123Next >
2530 107 2020-12-9
Blériot53
Flight distance : 6188465 ft
Finally! A break in the weather long enough to nip outdoors and experiment
Had to scale the resulting composition down quite a bit to meet the 2Mb constraint of the DJI Filter
2020-12-9
DowntownRDB
Flight distance : 1722 ft
Stunning pano Blériot.  Glad the weather was at least a bit cooperative.
2020-12-9
Blériot53
DowntownRDB Posted at 12-9 08:17
Just a long enough pause in the constant rain to nip across the road and down into the gorge. It's raining again now
2020-12-9
Blériot53
A second Pano, this time using Microsoft ICE rather than the DJI Media Maker
2020-12-9
Montfrooij
Flight distance : 2560453 ft
Looks good!
2020-12-9
Montfrooij
Not sure if you can, but I usually set the exposure compensation to -0.7 or even further down to get a well exposed sky (and bring back the dark areas in post)
2020-12-9
Blériot53
Thanks Monty.
2020-12-9
Blériot53
Montfrooij Posted at 12-9 09:02
I'm still finding my way around the various menus on this thing. It's so tiny they're not the easiest of things to locate   One thing at a time, I'm learning a bit more each day
2020-12-9
Montfrooij
You're welcome!
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 09:04
I totally get that.
The upside is : there is a screen (so you don't need a phone per se)
The downside is obvious....
It is tiny.
2020-12-9
Blériot53
Montfrooij Posted at 12-9 09:45
I totally get that.
Apart from connecting the smartphone to the Pocket 2 one time in order to register the device with DJI, I haven't connected it since.  I consider the connector to be much too flimsy (weak) and at great risk of sustaining damage without some additional kind of support between the two devices.
2020-12-9
A J
Flight distance : 13926112 ft
Lovely pano mate
2020-12-9
Blériot53
A J Posted at 12-9 10:47
Lovely pano mate
Thanks AJ. I did a similar one and this time I rendered it with M/Soft ICE rather than the DJI offering..  I think it's slightly better.
2020-12-9
A J
Blériot53 Posted at 12-9 08:39
Looks great - slightly more detail
2020-12-9
A J
Blériot53 Posted at 12-9 10:50
2020-12-9
Blériot53
A J Posted at 12-9 10:59
I need more time with it, but the weather isn't helping just yet.
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 10:07
My thoughts exactly.
I think I will do with just the P2 and nothing more.
2020-12-9
Blériot53
Montfrooij Posted at 12-9 11:07
I do find the do-it-all handle quite useful, but i's a nuisance having to disconnect it to download to the PC. It should be possible to do so through the USB port of the handle, but it doesn't work for some reason.
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 11:44
What do you find useful about it?
2020-12-9
Blériot53
Montfrooij Posted at 12-9 12:08
Handling, in a word   The camera on its own is a bit too small for my clumsy fist
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 12:11
I have heard that one before indeed.
I will have to figure out if the device alone is 'enough'.
Maybe with just the tripod mount mounted.
Or does that not make enough difference?
I have little use for that wireless mic, so the creator combo feels a bit too much for me (but the handle alone is almost as pricey as the combo, so in a way it is sort of a waste not to get that one)
But I rather just buy the device than spend and extra €140 on the combo.
Also because I wonder if it makes the thing more 'top heavy' on a tripod and therefore more vulnerable to the wind.
(the OM1 had this issue a lot, and even with P2 I see some hiccups in motion timelapses that could be caused by the wind)
2020-12-9
Blériot53
Montfrooij Posted at 12-9 12:21
The folding tripod supplied would be OK with just the camera on it , but it would perhaps be easy to overbalance in a strong wind - particularly when you consider adding the do-it-all handle. Also, it does not stand vertically, due to its design (retracting in a circular fashion) It relies on the gimbal resetting to horizontal when switched on. There is a secondary screw hole on the plastic pocket where, it is suggested, you can store the tripod when not in use. Unfortunately - again due to constraints of design - this leaves the attachment sticking out at an awkward angle where it impedes holding, and snags on clothing pockets when trying to put it away.
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 12:29
If I'm not mistaken, there is a small tripod mount that you can 'mount' to the P2 (instead of the do it all handle).
Or did I completely misread the accessoire list?
2020-12-9
Blériot53
Montfrooij Posted at 12-9 12:33
No you're quite right, but it's the screw on the min-tripod that isn't in the vertical axis when placed on a flat horizontal surface. SO the camera has a distinct lean. when switched on, the gimbal self-corrects to horizontal.
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 12:43
That is a weird design choice.
I am wondering if the tripod mount would be sufficient to give the P2 a bit more length for comfortable holding?
2020-12-9
Blériot53
Montfrooij Posted at 12-9 12:46
There's a longer handle but it's an additional £69 which is excessive. (Exorbitant is the word I would use)
2020-12-9
Blériot53
2020-12-9
Blériot53
Sorry about the poor quality of the image, but you seen the lean?
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 13:03
No problem!
Yeah I see it.
Weird.
And how does the P2 handle with just the mount?
2020-12-9
Montfrooij
So just this one.
Does it make it more comfortable to hold?
2020-12-9
Blériot53
Montfrooij Posted at 12-9 13:08
No problem!
Yeah I see it.
Weird.
Right. I've made some discoveries in the last half hour by experimenting.
The bottom cap of the camera detaches, as you know, to allow the addition of the accessories.
It comes off quite easily, and the do-it-all handle replaces it satisfactorily. It has a screw thread for the tripod mount. There is also a smaller attachment instead of the other two, which is just a tripod mount.
All this, I'm sure you know. But once attached, the tripod mount is the absolute devil to get off again, as someone already reported in my thread "A word of warning". I used the tripod as leverage to aid the detaching - and in doing so, un-noticed, twisted the screwthread out of vertical alignment. This is what was causing the lean!  I've twisted it back to vertical now. So you can disregard the comments about leaning
2020-12-9
Blériot53
That's the one which it's very difficult to remove once you've snapped it on.
2020-12-9
Blériot53
And no significant aid to holding securely.
2020-12-9
fansfe82067d
Indeed the tripod has a tiny ball joint so you can angle it as required - and fold it flat against the case after use.
There are many designs of phone-and-pocket holders on the market - my favourite is from StartRC which mounts the camera behind the phone, not beside it.  And you can attach a mini tripod beneath which when folded makes a handle, and when unfolded allows you to put the whole thing down.
https://www.amazon.com/STARTRC-P ... apter/dp/B07PF34RCM
2020-12-9
DJI Stephen
Hello there Blériot53. Thank you for reaching out and for posting this beautiful panoramic photo you have shot using your DJI Pocket 2. Great work and keep on shooting. .
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 13:16
Ah ok, I did read about that indeed.
(that it was very very tight)
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 13:24
Hmmm.
But I will deed it to attach it to a tripod if I don't get the diah right?
And is there other things you can't do with the tripod mount mounted?
(is there a reason to take it off if you don't have the diah)?
2020-12-9
Montfrooij
Blériot53 Posted at 12-9 13:25
That is too bad.
I was hoping it would make the P2 a bit longer.
2020-12-9
Montfrooij
fansfe82067d Posted at 12-9 14:24
Looks nice!
2020-12-9
Blériot53
DJI Stephen Posted at 12-9 20:53
Thanks DJI Stephen
2020-12-9
123Next >
