Fromanza
South Africa
Hi All,
I have the Fuji XT3 & RSC2, both latest firmware as of this message, connected with USBC cable. Tested with 16mm 1.4 lens so far.
I found a hack to get the pull focus using the front wheel working a bit better, still not great but it leads me to believe that its partly the DJI implementation of the Fuji SDK as to why these functions are not working.
On the gimbal, set the front wheel to "Focus/Zoom" set both the variables to 0. If you dont and try to use the front wheel then the focus runs away either on or out at super speed and it seems to pull focus even when the wheel stops moving, like a delay...
The trick I found is that if you go into the app, connect to the gimbal, turn on camera and then navigate to "create"-"camera settings" and then click on focus speed. Set this to 1. Note that on the gimbal you can only set this in increments of 5. (if the camera is off then you wont have the "camera settings" option.
If you go back to the gimbal then youll see that the focus speed is infact 1 and that the focus pull on the front wheel is actually usable to some degree. On the 16mm its very 'floaty' at larger focal distances but its WAAAY better than the on-gimbal setting of 0 or 5. Ill try the 18-55; 23 & 50-140 later.
This is the only function that I can get to work ther than start/stop video. No photo taking, aperture works in still mode buts kinda useless if you cant take pics, no shutter speed either. |
