JohnDG
Flight distance : 1097270 ft
Malaysia
keithtoo Posted at 12-11 19:00
So in the first point, this memory card IS listed in the DJI website (which is why I took care to specify exactly what appears on the packaging and the label on the card itself).
In the second point, the striping that occurs when the sensor is overexposed appear as diagonal lines through the overexposed area of the shot which would also include brightly lit white objects which is what I was targeting in the distance below the horizon. And, AFAIK, that feature has to be turned on in order to give such a warning - it wasn't. Since I do other photography, I've gotten pretty good at spotting the potential of pinning the lights and darks, but I also use the histogram feature that had my color range completely in the middle at both ends. And then, the video itself doesn't show any sign of over- or underexposure.
as I understand it good, the "ant" distortion is not on the recorded video, only on what is transmitted to your smartphone.
You can try to put your phone in flight mode, to exclude any interferance from your phone radio's (WiFi, bluetooth, mobile data).
I am using a S20 Fe 5G, but didn't any of those problems.
And as you use a recomended sd card, I would rule out the card as well.
Get in touch with DJI if the problem stays on. |
