GB44
Flight distance : 343848 ft
Surely what you do is create Ground Control Points around the various properties, do an automated flight using perhaps a grid flight path with a minimum of 5 Control Points fixed around teh property site, then input the specific coordinates of the Ground Control Points previous recorded into the software. You should be able to overlay the aerial photography or import into CAD etc. onto a known map.
Contact the above links for further help.
Also check out Agisoft software who also produce a software for collection of geospatial data to produce 3D models - same as Pix4D
Good luck
