RachelGomez
India
If you're experiencing connection issues with your DJI M300 RTK drone, here are some steps you can take to try and resolve the problem:
Check the battery levels: Ensure that the batteries are sufficiently charged, as low battery levels can sometimes cause connection issues.
Check the antennas: Make sure that the antennas are properly attached to the remote controller and the drone, and that they are not damaged or obstructed in any way.
Check the connection cables: Ensure that all cables are connected securely and are not damaged or frayed.
Update the firmware: Check for firmware updates for both the drone and the remote controller, and make sure they are up-to-date. You can do this using the DJI Assistant 2 software.
Regards,
Rachel Gomez |
