Wifi Pairing
10714 28 2020-12-20
Blériot53
Flight distance : 6188465 ft
I have the Pocket 2 and Creator combo. Successfully registered with DJI using Galaxy S9 and USB 3 connector.
I have two other Android devices, each of which works fine with all my drones.
However, I now discover that the Pocket 2 will ONLY pair with the device on which it was registered.
It flatly refuses to connect to either of the others, even though they can 'see' eachother with bluetooth enabled.
Anybody discovered a workaround?
2020-12-20
fansfe82067d
If you go into the wifi settings of your phone, can you connect to the wifi of the Pocket 2?
2020-12-20
Blériot53
fansfe82067d Posted at 12-20 06:07
The phone I registered with connects without hesitation.  My other phone and the Android tablet will not. A four-digit code is issued and compared, by each device, and pairing is attempted but always fails after about 20 seconds. Proximity is not an issue - I've even had them touching. Makes no difference.
2020-12-20
DAFlys
Turn off bluetooth on the one its paired to and then try on the other device.
2020-12-20
Blériot53
DAFlys Posted at 12-20 08:31
Nope. Makes no difference. Still Connection Failed.
2020-12-20
DJI Gamora
Hi, Blériot53. Thanks for reaching out and we're sorry to read about the difficulties you're encountering. We suggest performing a quick on the DJI Pocket 2 then try to reconnect to your other devices to see if it helps. Please check also whether performing a Network Reset on the mobile device you want to pair the DJI Pocket 2 would work. Kindly keep us updated.
2020-12-20
Alevpi
Flight distance : 43560 ft
I normally connect on 2 phones and 1 tablet in the Android OS, everywhere the same Google account and DJI Mimo, but I do not connect to the iPad mini 5....
2020-12-20
Blériot53
DJI Gamora Posted at 12-20 23:03
Hi DJI Gamora. I don't understand "performing a quick" in reference to the DJI Pocket 2. That has no meaning, please clarify.  As to the Network Reset suggested, it doesn't work on either device - the result is still the same.  I still have the one original smartphone (Android) which pairs without difficulty, so I am able to connect to this one device. But I cannot understand why my other two Android devices ( one tablet and one smartphone) will not connect whatever I try. I've followed the onscreen help popups in the Mimo App, but everything ends in failure.
For reference the three devices are:
Samsung Galaxy S9 - the one which connects successfully and with which I registered the Pocket2
Samsung Galaxy S7
Samsung Galaxy Tab S2 (8 inch tablet)
Regards
2020-12-21
Blériot53
Alevpi Posted at 12-20 23:19
Hi. It shouldn't be a problem, and it makes no sense that it works perfectly on one device and not at all on the others.  All are Android in my case.
2020-12-21
DJI Gamora
Blériot53 Posted at 12-21 00:31
Sorry for the confusion. Kindly access the system settings of the DJI Pocket 2 and reset the system parameters. You can check this video as this also a similar application.
2020-12-21
Blériot53
DJI Gamora Posted at 12-21 02:10
https://www.youtube.com/watch?v=YFHPAiZv7uk&ab_channel=DJISupport
OK I have done as you suggest and this has made no difference whatsoever. The Pocket 2 and the S7 see eachother, and a 4 digit code is displayed to accept.  But the pairing still fails, exactly as before.  Very unsatisfactory
2020-12-21
Blériot53
And what is worse. Now NONE of my devices will pair with the Pocket 2!  So your "advice" has left me in a worse situation than I was before   I cannot connect by wifi at all. This is unacceptable.
2020-12-21
DJI Gamora
Blériot53 Posted at 12-21 02:26
Please check whether restarting both the DJI Pocket 2 and your mobile devices would resolve the issue. Should the same problem persists, we recommend attaching a video depicting the issue including both the firmware version of the DJI Pocket 2 and the DJI Mimo app. We're sorry for the inconvenience it has caused.
2020-12-21
Blériot53
DJI Gamora Posted at 12-21 04:14
I've done so many switch on/off, restarts and pairing attempts, I've had enough of it now.  Nothing works. I've managed to re-pair the Galaxy S9 with the Pocket2, after half an hour of frustration.  The other two devices simply will NOT pair with the Pocket 2.  Mimo version is the same on all devices, and when queried reports "Version Detection  v1.5.4(161205) - Your App is up to date".  You have all the information necessary to outline the problem, and I consider trying to video the whole sorry experience to be a futile waste of my time.  I can only conclude that the problem lies in the inadequacies of programming or firmware, since all my devices work perfectly in all other respects, including controlling and flying my DJI Drones.  I'll wait to see if a future "update" resolves the problem.
2020-12-21
DJI Gamora
Blériot53 Posted at 12-21 04:55
Thanks for the information and again, our sincere apologies for the inconvenience it has caused. We'll have this checked with our engineers and request any feedback. We ask for your further patience while we're looking for a solution.
2020-12-21
DJI Gamora
Hi, Blériot53. We just received feedback regarding your previous submission. As per the review, different products have different connection requirements meaning that even if it can be used to our DJI drone, it isn't a complete assurance that it'll do the same with the DJI Pocket 2. On the other hand, you can try to turn off Wi-Fi Assistant and Wi-FI+ function on your mobile device before connecting to the DJI Pocket 2 via Wi-Fi to see if that helps as both functions will disconnect Wi-Fi that isn't connected to the Internet to ensure connectivity. Please be noted also that the devices that aren't listed within the compatible devices aren't guaranteed to work as they aren't officially tested but the support for additional devices available as testing and development continues.
2020-12-23
fansfe82067d
There was an issue mentioned weeks ago where the Pocket 2 wifi would be set to the frequency of the first phone it connected to, so if other devices didn't support that frequency, then it wouldn't pair.  That's why I wondered whether the phone's wifi could see the Pocket 2 wifi signal.  For instance, mine is locked onto 5G - my non-5G phone doesn't see it.  MY 5G tablet (which does not have Mimo installed) does see it.  It takes a minute or two sometimes to show up after starting the Pocket 2.
2020-12-23
fansfe82067d
Addendum - out of interest I tried installing Mimo on an Android 6 tablet - that gave me a warning about OS version (I think it wanted version  7 or higher) - it wouldn't connect automatically but I connected BT and Wifi manually, then it just exited from the app with a message that was basically "unsupported".  I don't know whether that has any bearing on your problem.
2020-12-23
Blériot53
fansfe82067d Posted at 12-23 17:06
Maybe that was the issue DJI Gamora was trying to address with the suggestion in #10, above, by proposing  a reset.  That didn't work, however.  It shouldn't be beyond the whit of the programmers to resolve this problem - which shouldn't exist in the first place, but I'm not holding my breath for them to come up with a solution anytime soon.
2020-12-23
Blériot53
fansfe82067d Posted at 12-23 17:44
Each of the 3 devices I use has the latest version of DJI Mimo installed, and Auto Updates for their Android version.
2020-12-24
Alevpi
Russia
I have 3 Android devices and it connects to all of them normally.
But there is also an iPad Mini 5, it supports 2.4 and 5G and Pocket 2 also absolutely does not want to connect to it!
2020-12-24
heightoffield
Flight distance : 2670423 ft
Hungary
try this thread, it solved for me: https://forum.dji.com/forum.php? ... D765%26typeid%3D765
basically, you have to connect via usb, set the frequency to 2,8 ghz, then connect with the handle via wifi (before that: reset the pocket wifi network settings in the wifi settings ON YOUR PHONE). cheers.
2020-12-25
Alevpi
Russia
I have 3 Android and 1 iOs devices do not have the ability to select a WI-Fi range and all devices have the latest version of DJI Mimo!
But I solved the problem with connecting the iPad Mini 5, just connected the Pocket 2 directly via the Lightning connector (USB), and then disconnected the adapter and connected the joystick and after that my iPad connected via WI-FI.
2020-12-25
Blériot53
heightoffield Posted at 12-25 15:31
Tried all that. Still the same result:  Connection Failed.
2020-12-28
Blériot53
Alevpi Posted at 12-25 22:23
Tried all these suggestions ( not ipad, don't have one) but for Android the result is still the same - Connection Failed.
2020-12-28
djiuser_VIjouADksJuv
Egypt
Такая же самая проблема! Как решилось?
2021-4-18
HGDC84
Finland
Blériot53 Posted at 2020-12-21 00:31
I have been keeping a list of Mimo compatible phones not listed on DJI's official list (the thread is available at https://forum.dji.com/forum.php?mod=viewthread&tid=235190 ), and on this thread, username MKosmo has stated that he has succesfully used Samsung S7 with his Pocket 2. Possibly you could ask him how he did it?
2021-4-18
Henry05
Blériot53 Posted at 2020-12-21 02:36
Me too! I tried two already none of the pocket 2 can be found on nimos app. Said no device found
2021-4-22
Blériot53
Henry05 Posted at 4-22 21:01
There have been a number of suggestions proposed on this thread - none of which work for me.  The ONLY device that the Pocket 2 will pair with is the one originally used to register it. All other devices fail to pair.
2021-4-22
