DJI Mini 2 Firmware Released (12/16/2020)
1279 5 2020-12-23
u.frenzelarcor.de
Flight distance : 26578 ft
Some Pilots have Problems with the Range after installed the new Firmware
2020-12-23
DJI Gamora
Hi, u.frenzelarcor.de. Thanks for reaching out! Could you let us know if you do encounter the same result? If yes, have you tried flying to different locations to see if that helps? If you could kindly, please let us know also the version of your DJI Fly and your DJI Mini 2's firmware version.
2020-12-23
u.frenzelarcor.de
DJI Gamora Posted at 12-23 03:25
Yes... I have the same Problems in different locations.
Since I have uninstalled the old firmware, I cannot compare directly.
But really think that the range has decreased.
DJI Mini 2:   0.1.01.0700
DJI fly: 02.00.1101
2020-12-23
DowntownRDB
Flight distance : 1722 ft
Thanks for sharing.
2020-12-23
Montfrooij
Flight distance : 2560453 ft
Thanks for the video!
2020-12-23
fansc9d1e824
I’m not having signal issues! It helped my signal in my test locations for flying. For example farthest I got in heavy signal interference city area was 13,000 or so feet flying out... with new firmware I got out same area and flight path and direction in heavy signal interference city area over 15,000 feet with one or two bars of radio strength and could of flown maybe up to 16,000 feet out or three miles but was worried about battery.. so I think distance or signal strength improved...
2020-12-24
