Ned help inspire 1 v.2
983 4 2020-12-24
NANO64
Chile
In the control i se in RADIO CHANNEL QUALITY APPEARS  POOR
What means that? Because is in red color.
Tks
2020-12-24
DJI Stephen
Hello there NANO64. I am sorry for the trouble this has caused and thank you for reaching out. Are you receiving any error messages on the DJI Go application and can you please post a sample screenshot showing the said error message for us to be able to see and assist you further. Thank you.
2020-12-24
Matthew Dobrski
Flight distance : 1831050 ft
That means the communication between the drone and radio controller is weak. It's a warning. Lift the drone up, maintain VLOS. Do not proceed with flying any further away as you may experience disconnection. When this happen, in most situations the drone will enter emergency Return To Home procedure automatically, assuming good GPS reception.
2020-12-26
djiuser_RY5Kihu1Kspv
Flight distance : 13852 ft
Matthew Dobrski Posted at 2020-12-26 15:40
My inspire 1 cuts out at around 4 to 500 metres even when i have vlos. I cant get it to fly any further without it losing signal and going in to rth mode. Friends of mine have the mavic 2 and they c a n fly 4 to 5 kilometres and the inspire i thought would do the same. Any help be greatly appreciated
2021-1-1
Matthew Dobrski
djiuser_RY5Kihu1Kspv Posted at 1-1 08:07
Inspire 1 can be controlled WITHOUT camera or intervention of a device and application. In other words, you can fly the drone with radio controller only. If that doesn't work, most likely there's a problem with antennas. These are located under motors in landing gear and on radio. Check the wiring connections thoroughly.
2021-1-1
