JohnDG
Flight distance : 1097270 ft
Malaysia
well Pajomota,
there are a lot people complaining about a lot of problems on the former firmware and the v1.2.1 as well.
Some problems like the color shift in pano's in Adobe software and the orange line on the 4K video's are solved. Some extra features where introduced. And like always people are claiming the new firmware and software the cause of the problems they have.
I'm running v1.2.2 on a Samsung S20 fe and the latest firmware on the drone and controller. My drone does not drift and behaves normal.
Listed compatible only means that DJI has tested it. A lot of other devices might work as well. They didn't test it, so no garantee it will work 100%.
We cannot decide for you if using v1.2.1 is a better choice for you or will the v1.2.2 work on your Xiaomi. You can always uninstall and install the old version if it doesn't suit you.
Before flying far, test your aircraft nearby and test if it does all of the functions, fly up, down, left, right, check on stability, see if your aircraft drifts before taking it on a ride,...
Check you got enough satelites before taking off. Leave it floating in front of you for a minute, if it drifts, put it down and calibrate your IMU. Then test again. |
