HOW WORK LIGHTBRIDGE GROUND UNIT ANTENNAS ?
1275 4 2015-7-2
HUSKY
Poland
Welcome.
I wouldlike ask how work both antenna on lightbridge graund unit.  the two antenna on the ground station are for different purposes... one for Tx, and one for Rx. If i observe status 10 channels in APP when i mount only right antenna status are change, when i mount only left nothing change. How this work ?
Regards Przemek
2015-7-2
Mark97564
Flight distance : 2067749 ft
Antennas both need to be connected when lightbridge is turned on, your going to burn it out..  To answer your question, on the ground unit both antennas receive and 1 transmits rc data and on the air unit both antennas transmit and 1 receives the rc data
2015-7-5
DJI-Cathy
Pls mount both antennas before you turn on the LB, thanks a lot!
2015-7-6
HUSKY
Poland
DJI-Cathy Posted at 2015-7-7 10:49
Ok. Thank you. Ofcourse i allways mount both antennas. Bat if you was write "both antennas recive" signal why RSSI bar change only if right antenna is coneced, This is visible perfectly on LB app
2015-7-7
rdteam55.dji
R&D Team
HUSKY Posted at 2015-7-8 00:01
Ok. Thank you. Ofcourse i allways mount both antennas. Bat if you was write "both antennas recive" ...
Hi, Husky. For LB's communication technology, MIMO is used. So one antenna maybe no problem in short range. But if you want to get better performance in long range, two antennas are a must.
And avoid damage, two antennas must be mounted before turn on.
2015-7-26
