tcchow.g.m
Flight distance : 9647812 ft
Here are my results;
Test 1.
1. Use the .bin to earse 1.2.6 with success,
2. insert the 1.1.8 down form 1.2.6 with success,
3. insert the 1.1.9 up form 1.1.8 with success,
4. insert the 1.2.6 up form 1.1.9 with success,
The reason why I try to go back up to 1.2.6 because as read at different forum some people did not have any problem with it, so I am assuming the 1.2.6 bin file wan't install correctly. Had a week of test fly with that 1.2.6 it works perfectly with a tinny proble ( I bet some people doesn't belive what I said, but it is true. )
Test 2
1. insert the .bin to earse again form 1.2.6 with success,
3. insert the SDK P3X_FW_V01.01.1007 rm 1.1.8 with success,
Because I want to play with those Litchi & FPV and DSI third party apps, I had that since then till now. It work perfectly without any issue.
Test 3
1. insert the .bin to earse SDK P3X_FW_V01.01.1007 with success,
2. insert the 1.1.8 down form SDK P3X_FW_V01.01.1007 with success,
As I already reported to Robrogkr about that issue, which means that .bin file are also works with the SDK P3X_FW_V01.01.1007. Now I am back on to the SDK P3X_FW_V01.01.1007 and so happy to playing with the third party apps. Hope the above will help others who would like to try to down grade and to belive that .bin are are really works with our P3 P/A. Thank you Robrogkr.
Packet: P3X_FW_V01.02.0006.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.01.0009.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:15 remo-con disconnect======
Packet: P3X_FW_V01.01.0008.bin
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:13 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.01.1007.bin
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
