Mounting the Canon C70 on the Ronin RS2
1419 5 1-3 08:14
swild
Flight distance : 141932 ft
I found it difficult to mount the C70 on Ronon RS2 using the supplied 1/4-20 screw. The C70's main tripod mount is a 3/8" hole and the 1/4-20 ones are to the left and right of it making it hard to balance on the Ronin no matter how you arrange it.
I found some 1/4-20 to 3/8 adapters that work great.
Buy these:
https://www.amazon.com/dp/B00OKY ... ding=UTF8&psc=1
These work great because they fit all the way inside the C70's 3/8" tripod mount.
These other ones I found don't fit flush with the bottom of the C70 causing mounting issues and make the camera wobble when operating, so don't buy those type of adapters.
1-3 08:14
DJI Wanda
Hi there, thanks for sharing your experience on mounting the Canon C70.
You can also try the extended baseplate https://tilta.com/shop/extended-quick-release-baseplate/
However, currently the Canon C70 is not compatible on the RS2 as the USB-C is not supportive by this model, we are working on with the third party to make compatible cable that supports the camera functions.
Let us know if you still have any questions, cheers
1-4 04:29
chalkgsy
DJI Wanda Posted at 1-4 04:29
Hi DJI Wanda.
I was wondering if you had any update at all about the Ronin RS 2 and the Canon C70 at all?  I'm just hovering over buying one but have seen a few threads like these with potential issues?
Can you let me know if it's compatible or will be in the future, or if not if you have any recommendation for a different model?
Thanks!
1-11 00:18
Chillaz
Thats weird because in my case the c70 works just fine with the usb c. I can sharp the autofocus lens (canon 24 -105 IS) for example by the indexfinger wheel when the camera is connected by usb c.
What functions are the ones you mean are not supported yet?
1-11 03:53
C70User
Flight distance : 1404 ft
Chillaz Posted at 1-11 03:53
That's interesting, because when I connect the C70 to the RS2 by USB C it works for a very short time, and then the C70 completely freezes - I have to remove the battery to get it to work again. Firmware on both camera and gimbal is up to date.
Do you have any special setting in the C70s menu? Did you use the USB C cable supplied with the RS2? Grateful for any suggestions which would make things work without having to wait for the new cable.
1-12 01:48
fans936e0407
Flight distance : 88212 ft
C70User Posted at 1-12 01:48
Same experience on my end, up to date and camera freezes when connected via provided USB C.
2-15 09:56
