Mini 2 jello effect when camera facing all the way downward
1914 10 2021-1-4
realstreetuk
Flight distance : 7966 ft
Hi Guys
Has anyone else noticed on dji mini 2? when i face the camera fully downward position i get the shaky jello effect like a wobble.
I have attached a my video of the problem as you will see its fine going forward but as soon camera is downward it happens.
It didnt happen with previous firmwares and previous app firmware.
I have samsung s20 ultra so running andriod. I have calibrated the gimal but still fault is present.
This does not happen when camera is facing forward or near to the fully downward position.
any information about this would be appreciated.
Thanks in advance
John
2021-1-4
videoeditman
Flight distance : 6713271 ft
I have not seen this, we will see if anyone else has an idea?
2021-1-4
Geebax
It means the camera is vibrating, most likely because one or more of the props has a nick in it. Try examining the props and replace any ones that have a ding in them.
2021-1-4
DJI Stephen
Hello there realstreetuk. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try to check the propellers of your DJI Mini 2 if there are damages or cracks this could be the reason why this issue is happening on your footages. Thank you.
2021-1-4
realstreetuk
The props look fine. And it's ok with camera in normal position if props were the problem would it have jello effect when flying with camera In normal position ?
Thanks for replies
2021-1-5
DukeofDrones
Flight distance : 12885007 ft
Could it be that the Heating is on Full Blast in those houses and not very good insulation ?
2021-1-5
realstreetuk
No that's not it as I have other footage in fields etc and still does it..
2021-1-5
Geebax
realstreetuk Posted at 1-5 02:15
Thanks for replies
There is only one cause of the Jello Effect, camera vibration, as I have already said.
2021-1-5
realstreetuk
Geebax Posted at 1-5 13:56
I hear you but does not vibrate in normal or close to fully downward position. Was ok with the previous fimware before last 2?
2021-1-5
Geebax
realstreetuk Posted at 1-5 14:15
The position of the camera can affect whether there is vibration or not. But in any event, if you are wondering if the firmware update caused it, the answer is no.
2021-1-5
fans017bca4d
Flight distance : 13 ft
I'm happy to see that with the mini 2 we have the right to fly over residential neighborhoods and film. because with my phantom it was forbidden.  probably too heavy.
2021-1-5
