Mobile SDK differences for M300/M2ED
214 3 1-8 02:03
mick11
I have developed an app that posts frames from the camera along with metadata using HTTP.  To get the frames I have set a new SurfaceTextureListener on the fpvWidget in initUI:
fpvWidget = findViewById<View>(R.id.fpv_widget) as FPVWidget
fpvWidget?.surfaceTextureListener = object : SurfaceTextureListener {
  override fun onSurfaceTextureAvailable(surface: SurfaceTexture, surf_width: Int, surf_height: Int) {
    codecManager = DJICodecManager(applicationContext, surface, width, height)
This means I can get the raw image data later with:
val data = codecManager?.getYuvData(width, height)
This works perfectly on the Mavic 2 Enterprise Dual.
This does not work on the M300 with H20T.
Setting the SurfaceTextureListener on the fpvWidget on the M300 kills the video display on the widget and I can't access the image data.  If I don't set the listener I can see the video display fine.
Can someone tell me why the behaviour is different, and how I can get screen grabs from the H20T feed on the M300?
Thanks,
Mick
1-8 02:03
kv886
South Africa
Because UXSDK is not compatible with H20
1-8 02:45
mick11
kv886 Posted at 1-8 02:45
Oh that's a shame, though it's weird that if I don't set the SurfaceTextureListener the FPVWidget works as you would expect (though I have not tried to do much else with it).
Can you suggest another way I could grab frames from the video feed?
1-8 04:42
mick11
For anyone else who comes across this, the solution was to use a standard Android TextureView instead of an FPVWidget and then it worked as expected.
1-24 22:03
