DJWacko
Flight distance : 126407 ft
Geebax Posted at 1-8 18:41
I can't say a lot about charging the MA2, I have a Mavic 2 Pro, but only use the supplied mains charger. But previously I had a P3 Pro and a charger that plugged into the cigarette lighter in the car. It was slightly slower than using the supplied mains charger.
If you do get the car charger for the Air 2, it will probably be much the same. There is not a lot of point in getting an inverter, as there is a massive inefficiency in charging that way, but if you do decide to go that way, make sure you buy a proper sine-wave output inverter, because the charger will hate the cheaper square-wave inverter.
Thanks for your advice , l was thinking about 1000 watt pure sine wave inverter as the caravan has sufficient battery power. But more expensive than car charger.. cheers |
