InspirelessAggi
If memory serves, I think that's a point on the gimbal where two pieces are coming together. Not sure if it's a defect. I can't see your crack. Maybe it is.
As far as the plastic under the motor, yes. It will get worse. I have posted pictures of mine. It started with the cracking around the hole and then it spread to between motor mounts. It's just a matter of time until the motor comes off on mine. No crashes, just normal use. I think there should be a recall on all these. More and more people are coming forth with the cracks. You guys monitor those areas and inspect them after your flights.
Evidently, better motors were used on the phantom 3 but from the looks of comparison pictures between the phantom 2 and phantom 3, they didn't do much to make the arms stronger
Here's mine. Started at the screw hole. I tried to put CA glue to arrest the crack but it progressed anyway to the center under the motor
http://youtu.be/g7XAWYQ2kKk
