BaliSkies
hallmark007 Posted at 1-11 13:30
A bit of advice, delete an re install FW , I also had similar problem and from experience I know updates can be sometimes sketchy. So i deleted and updated flew and had no problems.
It’s not a guaranteed fix but worth a try.
As far as I know, this is not possible with the Mini 2. The DJI Assistant only lets you export logs. It does not provide the function to delete and refresh firmware. How do you achieve this using your computer (as you suggest) without DJI Assistant? I don't believe this to be possible.
I think you are referring to the Mini 1.
