Beta firmware for DJI RSC2 available
3854 8 2021-1-13
DJI-Paul
Flight distance : 41159547 ft
Thank you for your interest in this beta firmware. By downloading or using this beta firmware, you hereby signify that you have read carefully and that you understand and agree to abide by the terms and conditions herein:
1. Beta firmware is not yet fully tested and is mainly used to gather feedback prior to regular release. This enables users to be involved with the development process and for any necessary changes to be made prior to the regular release schedule.
2. The beta firmware and all related services are provided "AS IS" and, to the maximum extent allowable under law, DJI disclaims all warranties of any kind, whether express or implied, including any warranties of merchantability, fitness for a particular purpose, and non-infringement. Without limiting the foregoing, DJI does not warrant that operation of the beta firmware will be uninterrupted or error-free, that the beta firmware will be compatible with any products including designated DJI product models.
3. DJI will not be liable to you for any personal injury, property damage, lost profits, cost of substitute goods, loss of data or any other form of direct or indirect, special, incidental, consequential or punitive damages from any causes of action arising out of or related to this agreement or the beta firmware, whether arising in tort (including negligence), contract, strict liability or otherwise, whether or not DJI has been advised of the possibility of those damages.
4. If you find any abnormality when using the beta firmware, we recommend that you take the following steps:
a. Send feedback on the problems you encounter. You may contact us through our firmware release channel (whether DJI’s Official Forum, or the Official DJI RS2/RSC2 Owners Facebook Group);
b. It’s possible to downgrade to a previous version of the official firmware. Set the gimbal to sleep mode, go back to the homepage of the App, and click the upgrade notice. The original gimbal firmware should then be restored.
RSC2 Beta
What’s New?
• Added Orbit Follow mode.
• Added manual setting for focus endpoints for DJI Ronin Focus Motor, where users can set a controllable range between Point A to Point B manually.
• Added Deep Sleep mode to extend battery power. Press the gimbal power button twice to enter sleep mode, and the gimbal will automatically enter Deep Sleep mode after 10 minutes if no interaction has happened with the gimbal. The touchscreen will be set to its lowest brightness, and the RSA accessory expansion port will power off. Repeat to exit Deep Sleep mode.
• Added front dial control over camera parameters, shutter speed, gimbal tilt/pan movements. Also added adjustable front dial smoothness and direction reversal.
• Added shutter/autofocus control for Z CAM E2、Z CAM E2-F6、Z CAM E2-F8、Z CAM E2-M4、Z CAM E2-S6
• Optimized roll axes algorithm for large angle tracking in Horizontal, Portrait, and FPV modes, preventing the gimbal from getting stuck during tracking at specific angles.
• Fixed issues: The built-in screen flashes when the gimbal motor is stuck during rotation
• Fixed issues: calculation error of customized parameters in Panorama mode.
• Fixed issues: when using Z CAM with manual lenses, the gimbal axes failed to stabilize the camera.
Notes
• Make sure that the DJI Ronin app is the latest version when updating the firmware.
• Update the firmware using the DJI Ronin app by connecting the DJI RSC 2 via Bluetooth. Update the firmware of RavenEye transmission module separately by connecting it with DJI Ronin app via Wi-Fi. Do not disconnect the DJI Ronin app and DJI RSC 2 during the update. Do not disconnect the DJI Ronin app and DJI RSC 2 during the update.
• If DJI RSC2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
• If the firmware update fails, restart DJI RSC2 and retry.
Please keep all feedback and comments on topic in this post.
Beta App for Android will be posted here later to take advantage of some new features. iOS can't be distributed this way so iOS users will need to wait for the final version.
Beta Android App:
What’s New:
- New zoom time-lapse function allows control of the DJI R Focus Motor during time-lapse photography
- Control the DJI R Focus Motor within the RavenEye transmission screen.
- Added the ability to directly import LUT files on the phone created by third-party Apps into Ronin App
- Added clean screen function by tapping the RavenEye transmission screen removing Interface objects for a clean image transmission.
2021-1-13
DJI-Paul
Beta firmware for DJI RS 2 available
RS2 Beta
What’s New?
• Added ActiveTrack in Portrait mode when using with DJI R Vertical Camera Mount (click to purchase: https://store.dji.com/product/r-vertical-camera-mount).
• Added 720 VR mode.
• Optimized DJI R SDK repackage protocol, added set and id fields to differentiate from sub-package instructions
• Optimized roll axes algorithm for large angle tracking in Horizontal, Portrait, and FPV modes, preventing the gimbal from getting stuck during tracking or enter the above three modes at specific angles.
• Fixed occasional issues: The 3D Focus function acts abnormally when switching quickly from MF to AF.
Notes
• Make sure that the DJI Ronin Tethered Control Handle is the latest version when updating the firmware.
• Update the firmware using the DJI Ronin app by connecting the DJI RS 2 via Bluetooth. Update the firmware of RavenEye transmission module separately by connecting it with DJI Ronin app via Wi-Fi. Do not disconnect the DJI Ronin app and DJI RS 2 during the update.
• If DJI RS 2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
• If the firmware update fails, restart DJI RS 2 and retry.
2021-1-13
fans2fec9d24
Flight distance : 136115 ft
Sounds really great... unfortunately I'm on iPhone   Any approx. idea how long before it's out of Beta?
2021-1-13
DJI-Paul
fans2fec9d24 Posted at 1-13 11:42
These don't need the new iOS version of the app. You can do this with the current version now. Just the necessary functions that require the app won't be available to you yet. We don't have a set timeline.
2021-1-13
ralphp
Flight distance : 741 ft
New Caledonia
cool ! But no mention about Sony A7c compatibility. I will test it and let you know.
2021-1-13
AntDX316
Flight distance : 3394731 ft
Orbit follow mode?  There has to be more ways to have more control over the Activetrack.
2021-1-13
fans2fec9d24
DJI-Paul Posted at 1-13 13:24
Unfortunately it just offers me the possibility of updating to 1.02.00.03... which is the version I'm running... it even updates itself very quickly but no new firmware options are shown
2021-1-13
j3yps
Flight distance : 3402 ft
Philippines
ralphp Posted at 1-13 13:57
Hey Ralphp, any news on the A7C compatibility with this fw?
2021-1-22
ralphp
New Caledonia
j3yps Posted at 1-22 22:08
Hi, not yet. Been very busy. I just saw there is a new firmware release.
2021-2-2
