Matrice 600 PRO firmware update error
3709 5 2021-1-13
luigi_malusardi
Flight distance : 12756 ft
Hello,
I have a DJI Matrice 600 pro with a Zenmuse XT-2. Before and even after updating the camera firmware, the live feedback of the normal and thermic camera was greyed or even black without any image. I downloaded DJI Assistant 2 for Matrice and run the firmware update for the drone. After many tries it gives me always the same error code 0x0080100 . I can't find anything about this error on the internet. Do you guys now what this is about?
Image of the error displayed
Thanks for the help!
2021-1-13
djiuser_ODpYN2wDfrJC
I'm getting the same error. Did you ever find a solution?
2021-5-5
luigi_malusardi
djiuser_ODpYN2wDfrJC Posted at 5-5 11:46
I didn't found anything on the firmware update problem.
The live feedback from the XT2 wasn't working because of app compatibility... I was trying to use DJI GO but XT2 only works with DJI Pilot (as far as i know).
2021-5-5
djiuser_U2ujO3HVkQ6a
I'm having the same problem with my Matrice 600 Pro. I tried many times, and sometimes it completed the upload but after the reboot, it asks again to upgrade. It crashes usually at 99% but other times also at 25%.
2021-5-12
myrnostrum
So what worked for me was uninstalling the current version of DJI Assistant 2, and then installing an older version. This forum post was helpful:
https://forum.dji.com/forum.php?mod=viewthread&tid=216225
The firmware finished updating, and it never said "Current" next to the firmware in DJI Assistant 2, but when I checked the drone's firmware in the DJI Go app, it was the most recent version.
Good luck!
2021-5-14
Ozzyjim
Hello,
I also had a similar problem... I re-downloaded the Assistant 2 (ENTERPRISE EDITION) and Completed the firmware update using my phone as a WiFi hot spot to the computer... I don't know why it should make a difference but a local authorized repair man said they can have trouble finalizing the firmware upgrade when it needs to communicate back to the servers... Now I have the Lightbridge 2 , Controller and M600P All updated to the latest firmware. Now I don't know if it will tell me that I need to update the M600P again when I plug it back in to the PC to setup the controller expansion unit and map the F-ports but time will tell..
James.
2021-6-12
