NEED OPINION ABOUT ESC STATUS ERROR
350 2 2021-1-14
canmavic
Hi everbody, when i was using my mavic pro small piece of plastic was stuck between motor and arm so motor was stuck i didnt know and i tried to fly 3 times then i realized i took it of that piece now motor can spin but i have ESC STATUS ERROR and when i click i see 2NO. MOTOR ERROR. i refreshed firmware its same so i think i should replace the motor.
here is the questions
* is there any way to fixed except motor replacement
* if i have to replace motor which is easier ? replace motor or replace arm ( i think its easier )
* after replacement should i do something for firmware ?
thank you so much
2021-1-14
canmavic
I NEED OPINION ABOUT ESC STATUS ERROR
thank you so much
2021-1-14
DJI Stephen
Hello there canmavic. I am sorry for the trouble this has caused and thank you for reaching out. Since this issue is happening on your DJI Mavic Pro and you are getting this error message on the DJI Go 4 application. I would recommended and it would be best to contact our DJI Support Team at ( https://www.dji.com/support ) for further assistance and for further evaluation of the said DJI drone. We have a team that will do there best to check the said DJI drone and give out the best resolution for this issue. Again, I am sorry for this trouble and thank you for your understanding.
2021-1-14
