S1000 with GH4 shakes when flying
1131 4 2015-7-5
richardhuison
Flight distance : 54455 ft
Hi Folks,
I was testing the S1000 today and noticed that when i pushed the craft left or right, the gimbal would shake. And the motors would also. the craft flies great but the image is noticable. anything i should look for apart from any lose screws or missing rubber mounts?
2015-7-5
Pizmo75
Flight distance : 910735 ft
How many flights do you have on the s1000? Motor dampers could be the issue here..
2015-7-5
Pizmo75
B.t.w. flying pretty close to power lines.. no gimbal jitter but FC problems later on maybe?
2015-7-5
thurmant
The solution for me was to switch the propeller arms to different locations.  It seems as if the balancing done in production may have some process control issues, therefore causing a resonate harmonic to occur.  If you switch them around to different locations (bearing in mind the correct rotation for the correct location) you may cancel the harmonic effect.  Otherwise it's the time tested weights and balances drill.
2015-10-6
dennismurry08
Flight distance : 5948264 ft
What are your camera settings? Sometimes the camera picks up what appears to be vibrations but they are actually the camera settings.
2015-10-7
