Osmo Pocket WiFi Module
3955 11 2021-1-21
DroneMike7
I have just discovered how to extend the WiFi range of the Osmo Pocket with it's WiFi adaptor.
I bought a USB powered 300N Mini Smart Router/Repeater (extender) by GL.iNet Model GL-MT300N-V2 (other types should also work) which is a battery portable device costing £19.65.
Powered by it's mini USB socket connected to a powerbank it can be used anywhere outdoors enabling video with no stuttering, very low latency and extended range
The WiFi will now work through walls etc. and is perfect for true remote control of the Osmo Pocket. I've not done any outdoor range tests because we here in the UK are still in 'Lockdown'.
Setting up the repeater (extender) was not a straight forward affair, so below is the proceedure I eventually used after a whole morning of trial and error to get a reliable connection every time. I know this works with my iPhone and assume the proceedure will be much the same with an Android device:-
1. Switch on the repeater unit first
2. Switch on the Osmo Pocket with the Osmo Wi-Fi module connected and Start a recording (recording stops the Pocket from switching off before all the next steps are completed)
3. Switch on the iPhone Wi-Fi
4. Connect to "GL-MT300N-V2-9f2 (9f2 part may be specific to my particular repeater device)
                 DO NOT connect to "OsmoPocket - BCCDC7". THIS IS IMPORTANT!!
5. Start the Mimo App & ignore the message "DJI device found [connect]" (if you do tap on 'connect' you will be directly connected to the Pocket which is not what is wanted here)
    Instead WAIT till the message "DJI device connected [Camera]" appears and then tap "Camera"
Your Osmo Pocket will now be connected to your phone via the repeater's stronger signal and will give you much greater range
Hope this helps anyone who would like a more reliable greater range with their Osmo Pocket Wi-Fi
2021-1-21
DJI Stephen
Hello there DroneMike7. Thank you for reaching out and for sharing these information here at DJI Forum. Great experience and thank you for your support.
2021-1-21
DowntownRDB
Flight distance : 1722 ft
Very innovative.    Thanks for sharing.
2021-1-21
DowntownRDB
Did some more research on your posting and liked what I found.  I have ordered the GL.iNet Model GL-MT300N-V2.
2021-1-21
DroneMike7
DowntownRDB Posted at 1-21 07:57
Just tried it again in an upstairs room where the Virgin Media Hub is and found it very difficult to connect (using an iPhone SE 2016). I suspect the GL repeater signal is being swamped by the mains repeater I have up there which pumps out a powerful signal so I can watch TV reliably downstairs. Also found that the GL repeater ident did not always show up on the list of Wi-Fi devices, so I switched off the option to 'Auto-Connect' to my home broadband in "Settings" -> "WiFi" and found that helped. I've just done a comparison test connecting to the Osmo Pocket directly (in the same environment) and found the connectivity to be abysmal, so using the repeater/extender here makes a massive difference!
2021-1-21
DowntownRDB
DroneMike7 Posted at 1-21 09:43
Thanks for the follow up.  Stay safe and have a great day.
2021-1-22
djiuser_AjvhEcqinbIL
DowntownRDB Posted at 2021-1-22 04:14
How did you configure the repaeter?
Dont you have to connect it first to the osmo pocket 2?
Tried it but is not working..
2022-2-18
Psoon
Flight distance : 16279465 ft
Brilliant work-around. Should work great in the outdoors, not sure if this repeater can handle in an environment where theres overlapping industrial grade WiFi networks. Worth a try. Cheers
2022-6-5
Unclebob1953
Do you know a way to use the audio adaptor with the Wi-Fi module?  Using the Osmo 1 pocket.  I can't get any help from DJI support.
2022-6-5
hezmoz
Japan
Hey DroneMike7, I'm having trouble with getting my GL-MT300N-V2 to reliably locate and repeat the Osmo Pocket WiFi signal. It seems that it only shows up when it wants to and is not shown whenever the unit is on with the WiFi module connected. Have you been able to figure out a reliable power-on sequence to get this to work every time?
2023-7-5
HGDC84
Finland
That sounds very interesting, could come in handy with many scenarios. Any idea if this also works with the Pocket 2 Do-It-All Handle?
2023-7-5
hezmoz
Japan
I figured it out - my wifi extender is 2.4ghz only so I had to force the osmo pocket onto 2.4ghz through the Mimo app but there's also an option to do it in-camera
2023-7-6
