Gimbal sin estabilizarse
810 1 2021-1-23
Daniel Var
Chile
Hola BUenas Tardes
Hace un tiempo estrelle mi dron y compre entre los respuestos la camara con su gimbal del DJI SPARK, ya la parte electronica esta perfecta, vuela y todos los sensores funcionan correctamente, pero la camara al iniciar el dron no se estabiliza, se queda de ladeada, y a veces no sube ni baja... que dobo hacer en este caso es algo de software???
La camara tiene vision y su funciones manuales de Exposicion iso etc, funcionan correctamente
Cualquier ayuda lo agradezco...
2021-1-23
DJI Stephen
Hello there Daniel Var. I am sorry for the trouble this has caused and thank you for reaching out. Since there was a crash that happened on the said DJI Drone. It would be best to contact our DJI support team at https://www.dji.com/support . We have a team that will do there best to fix and give out the best resolution for this said issue. In addition, DJI do not recommend doing a DIY in fixing the said DJI drone to avoid further damaging the said unit. Again, I am sorry for the trouble and thank you.
2021-1-24
