hhackbarth
Flight distance : 375761 ft
Hi,
I am trying to get my new Lightbridge working with Wookong M and "Taranis X9D pus" radio control. After unpacking, all components were updated to latest firmware releases.
First, what is already working :
- Ground- and air aystem connect to each other, HDMI-vdeo and OSD (telemetry) is transmitted to ground system and displayed successfully on Android smartphone (connected via USB). Both LEDs on air system are green.
- On the smartphone app, video downlink shows about 92% signal strength and remote control link shows about 98%
- Taranis radio control is connected with cable (red plug on the RC) to trainer port bus, RC trainer mode configuration is set to "slave" and RF module is switched off. Air system D-bus cable is connected to X2 port of Wookong M flight controller. When RC is switched on, the warning "Control signal lost" dsappears from smartphone display.
- When I connect Lightbridge Assistent via USB cable to ground system, I can see in the channel display the movement of the RC control sticks for the first 4 channels (A/E/T/R).
Now, what is not working so far :
- When I connect the Lightbridge Assistent via USB to the Air System, the channel indicators do not show any reaction to movements of the controller sticks on the RC.
- Perhaps needless to say that the Wookong M Assistent connected to the USB port of the flight controllor does not show any reaction to the controller stick movement as well. Neither with setting to D-Bus, nor with setting to receiver type " PPM ".
Any idea what is missing or going wrong?
