Turn Off WiFi Pocket 2 Do It All Handle
1625 3 2021-1-29
SWATBoss
I've searched the forum and elsewhere but cannot find an answer.  Is there a way to turn off wifi on the Pocket 2 Do It All Handle?  It is introducing static using my Saramonic SR-XM1 microphone.
2021-1-29
Cients
Flight distance : 5537369 ft
Portugal
Did you solved the problem?
2021-1-29
SWATBoss
No solution yet.
2021-1-29
choisinc
South Korea
I have same issue. Every mic which requires plug-in power is getting horrible noise - but battery operated mics is getting no noise. If they can fix this problem by letting us be able to turn off wifi, that would be great. If it is hardware problem, we are screwed. Did you try with latest firmware?
2021-3-7
