TwentyThrill
Flight distance : 257133 ft
South Korea
DJI Gamora Posted at 1-29 23:24
Hi, TwentyThrill. Thanks for reaching out and our apologies for the difficulties you're encountering. If you have not tried yet, we recommend performing calibration also in the remote and perform another test. We suggest that you have it tested in an environment with the minimal wind to rule out this possibility. Please also check whether your propellers are still in good condition. If they're not, it is highly recommended to replace them with brand new set/s.
Hello DJI Gamora, thank you for your quick response. My RC don't require calibration because, as you can see from the flight logs, the issue comes when there's no RC imput on the sticks. The wind conditon at that high was almost absent with a maximum peek of 8 km/h as you can see from the weather data.
I accurately inspect the propellers before every single flight, no issue was found soever. I've just double checked their staus and I can confimr they're all clean, not damaged and in shape. |
