Control Ronin through Lightbridge?
2274 10 2015-7-8
Bridges Aerial
Can the Ronin be controlled  through the lightbridge? If it can how does the set up go?
2015-7-8
DJI-Cathy
Connect the Dbus of LB air end to the Dbus port of Ronin
2015-7-8
cookinghusband
Flight distance : 41463 ft
DJI-Cathy Posted at 2015-7-9 10:37
Dear Cathy,
Is there a connection diagram for connecting the Ronin-m and Ronin to the Light bridge system.
Thanks
2015-7-9
Bridges Aerial
Thanks Cathy. Then do I just connect the cable between the ground end and the ronin controller? Is the 3.5 mm socket in the back on the ronin controller for connecting to the lightbridge? Are there any other settings that need changing.
2015-7-10
DJI-Cathy
cookinghusband Posted at 2015-7-9 19:30
Dear Cathy,
Is there a connection diagram for connecting the Ronin-m and Ronin to the Light bridge ...
I am afraid not, just connect the D-bus cable from the ronin to your LB air end, do you have any trouble?
2015-7-10
DJI-Cathy
Bridges Aerial  Posted at 2015-7-10 17:44
Thanks Cathy. Then do I just connect the cable between the ground end and the ronin controller? Is ...
There is a D-Bus port on Ronin, connect it to your LB air end,  then connect your LB ground end to your remote controller
2015-7-10
jakelukas
Hi, I'm having a hard time finding information on this. Yes if i connect the dbus to the lightbridge there is communication.. However im using the lightbridge as the main receiver on my s1000 so the dbus is connected to the A2.  . So since im planning to mount the ronin-m on the s1000 I want to control the ronin-m via lightbridge as well. So what are my options? CAN port? if so where can i find a cable/adapter for this. Would this be enough to control the ronin-m? I want to leave the lightbridge receiver mounted to the fram of the s1000.  Not sure if anyone else managed to get this to work properly.
Thanks
Jake
2015-7-20
jarle.lervik
Flight distance : 77615 ft
Norway
jakelukas@hotma Posted at 2015-7-21 02:29
Hi, I'm having a hard time finding information on this. Yes if i connect the dbus to the lightbridge ...
Hi, did you figure out the best way for the S1000/Lightbridge/A2/Ronin-M combo, Jake?
2015-11-16
DJI-Cathy
jarle.lervik@gm Posted at 2015-11-16 20:11
That does not work, currently the ronin-m can not talk to your flight controller
2015-11-17
dvrekalic
DJI-Cathy Posted at 2015-11-17 05:18
I also have the DJI S1000 A2 setup but with LB 2 with new LB radio interface, all up to date.
Is it possible to carry the Ronin M and control both the S1000 / A2 and LB at same time with the LB radio?
Additionally if answer is yes, is it possible to control the Ronin M with Ronin Radio set as slave?
2016-1-25
DJI-Cathy
dvrekalic Posted at 2016-1-26 15:43
Is  ...
I am afraid not
2016-1-26
