DAFlys
Flight distance : 312090263 ft
djiuser_a5YpDiXYeS0m Posted at 9-29 21:30
I'm fairly certain this is incorrect. Charging cycles has nothing to do with the amount you charge or use. If you charge a battery, disconnect it from the charger, and even just let it sit and then plug it back in to charge, that will count as a second charging cycle.
This is an industry standard for charging devices. It has nothing to do with use, once you unplug it from the charger for a few moments and plug it back in, it will count as a second charging cycle. And that's the reason that the charger actually begins charging again.
These are intelligent batteries, one all 4 leds are lit if you disconnect and reconnect it will not be charged, so you can end up with a battery at 92% that until your discharge it a bit the charger wont start re charging. |
