crash1sttime
Flight distance : 1047503 ft
If you use the DJI app you will see that the altitude is always miles off what it actually is, ive had my quad hover in front of me and im 6ft tall, the app said it was 12ft off the ground, you can try letting the quad sit for a minute after startup then power off the quad and then power on the quad, this has proven to reset the altitude correctly occasionally.
That said the Naza unit is really bad at accurately measuring altitude due to its cheaper internal components, and there isn't much you can do about it, short of buying a top of the range unit.
