P3 4k not turning on - since one motor looks not working anymore
475 5 2021-2-14
maxmax11
Hello, I have a Phantom 3 4k.
Suddenly one motor stopped working and the drone cannot even start.
This is a video showing the phenomena:
https://www.youtube.com/watch?v=qVcMBXhUNZI
It tries to play the booting sound, but only three motors move an the sound suddenly stop after about 100 milliseconds. The other one is totally stuck. It repeat this behaviour forever.
Sometimes the sound is longer (like one half of the actual load sequence), sometimes is shorted. I guess is a control on the current of each motor.
There is another detail: in the beginning, this problem started when a motor stopped to work (the other three were warming up correctly, the last one was completely cold as no current were flowing). Sometimes, in the past, it completed the boot procedure (I don't know how) but it cannot fly because of the stuck motore (this is not happening anymore, since I can't get to turn it on.
This is a video how the problem started:
https://www.youtube.com/watch?v=wM6TUCOzllU
Do you think is the motor, or the ESC? Thank you in advance.
2021-2-14
JetSam
Flight distance : 3462946 ft
2021-2-14
JetSam
When was the last time you flew normally?
long time without using your drone?
2021-2-14
maxmax11
JetSam Posted at 2-14 08:21
Actually I lent it to a friend but, yes, as far as I know it flew normally (also, because there are no damage at all). The camera, by the way, always work, even if the drone does not start.
When I discovered the damage it was not used for about 4-5 months, now I am trying to fix it somehow (after 1 yr after the damage discovering).
I forgot to say that I have two batteries and with both the situation is the same.
2021-2-14
DJI Stephen
Hello there maxmax11. I am sorry to know that you are having issues with your DJI Phantom 3 4K and thank you for reachig out. After watching the videos that you have posted. I would recommend for you to contact our DJI support team at https://www.dji.com/support for further assistance. We have a professional team that will do there best to fix and give out the best resolution for this issue. Again I am sorry for this trouble and thank you.
2021-2-14
maxmax11
DJI Stephen Posted at 2-14 19:38
I wrote to the support, but they only suggest to send it to DJI. There is no major suspect? The ESC? The motor? If it can be the motor and there is a way to circumscrive the problem, I can linkely replace it.
2021-2-17
