fans3d7e7463
Flight distance : 1339793 ft
You're correct that the battery lights go out when the battery is fully charged. But, does it trickle charge or cycle on and off indefinitely as long is the drone/battery is on the charging stand. Now that you mention it, can you leave a drone/battery attached to a USB C charger cable indefinitely or should you remove the cable after the battery is charged? Perhaps I failed to research the charging process correctly regardless of dome, charging block, or USB C cable. |
