Gimbal roll wen turning right or left
1254 7 2021-2-25
daniel_ktm
Flight distance : 724301 ft
Hello everyone,
I have had this problem for the last year and still haven't been able to fix this roll in the gimbal. Please can someone suggest a solution, I've gon through all the settings and calibrated the gimball countless times.
These are some of the pictures from a test flight where turn fully left and right. After turning the gimbal takes a fiew seconds to full stabilize from tilting left or rignt.
First Picture:
This is when i make thedrone spin left, ( the gimbal banks right and slightly upwards)
Second Picture:
This is when I spin right, ( gimbal tilts left and slightly upewards)
Picture 2
Picture 2
Picture 1
Picture 1
2021-2-25
DJI Natalia
Hi there, may I know the model of your drone, please? At the same time, could you check if there is an error message prompt in your app? Thanks.
2021-2-25
daniel_ktm
Hello
My drone is a Phantom 4 Pro, and no no error messages are coming up on my screen, nor dose the gimbal seem to have this fault when you hold the drone in you’re hands and try to pan with it or move it.
2021-2-25
DJI Natalia
daniel_ktm Posted at 2-25 06:19
Hello
Thanks for the information. Could you provide me an original video from the SD card for further analysis? I'd like to help you check it. By the way, please check if the firmware for the drone and controller has been updated to the latest.
You may upload the original video to Dropbox or Google Drive and then share the link with me. Looking forward to hearing from you.
2021-2-25
daniel_ktm
Hello
2021-2-26
daniel_ktm
DJI Natalia Posted at 2-25 19:23
Hello sorry for the late response
This is the link to the video of this strange gimbal roll that I'm experiencing.
https://www.dropbox.com/s/fm348zfldfijbam/dji%20clip%20roll%20.mp4?dl=0
I hope you are able to help me resolve this issue as it is really annoying when panning, or following a moving object.
2021-5-22
Eric13
Flight distance : 13982031 ft
Is your gimbal mode set to FOLLOW?
If it is set to FPV the gimbal rolls...
2021-5-22
daniel_ktm
Eric13 Posted at 5-22 06:40
Hello yes I understand what you mean, but the drone dose this in both modes. And for FPV mode it should roll into the turning direction of the drone, at the moment it's turning in the opposite direction, like if it cant keep up with the gforce exerted by the drone turning. I think there might be a component that is faulty, sometimes when rested on a table the drone's gimbal hovers left and rights "very very slightly" again this might be normal, but I thought its worth adding.
oh and I obviously recalibrated the gimbal countless times.
2021-5-24
