Continuous video or short clips?
1334 7 2021-3-1
Borisaurus
Is it considered better to record a long continous video of the whole flight and then edit the pieces you're going to use,  or to shoot short clips while flying (stop/start record mid-flight)?
2021-3-1
DAFlys
If you film continuously you'll just need to make sure you have big enough SD card and be aware the clips are chunked into 4gb files so you may have the section you want across two files that you'll need to merge.
2021-3-2
David K
I think continuously! Today, a large SD card is not a problem
2021-3-15
ericveller
By pressing the button you can skip the brightest moments
2021-3-15
Cavu Films
Flight distance : 549295 ft
I've always just let the camera run during a flight and then do all the editing later. That way you can focus on flying and getting all the best angles of your subject. If you do the start/stop option you run the risk of forgetting if you started it and run the risk of missing a great shot.
2021-3-16
djiuser_FR3Lv7lSpYE3
I always worry that if I only have one long file and it becomes corrupted I could loose the entire shoot. I might run continuously, but I prefer to break the files up when I have a successful take for peace of mind
2021-5-12
DronePinhead
I prefer the video so I can always speed it up as needed. Single shots can be odd with wind.
2021-5-12
PatG
Flight distance : 526634 ft
Cavu Films Posted at 3-16 08:32
Yep very true I have started and stopped and forgot to start again.AAAAAAAAAAAARRRRRRRRggggggg
2021-5-17
