luciens
cootertwo Posted at 5-16 06:32
Well, I done been through all this stuff. I bought the FPV kit and was amazed at the video quality. So, bought 5 Vista kits, to upgrade some of my older analog drones. Then bought the V1 radio ($300). It's nice, BUT...
I found the video coming from the Vista's not quite as good as the new FPV setup. Also the range of the V1 radio leaves a whole lot to be desired. What is DJI gonna do? Who knows. I'm tinkering with my vista kits and Crossfire. Also have 2 full size Air units coming in the mail.
One problem with the "new" controller that comes with the FPV drone is, it has only two (3-position) switches. The others are all simple momentary SPST switches, and one wheel. That's not really enough to do a lot of what you want to do with a traditional F4/F7 Betaflight, etc. quad. You can routinely tie up at least 4 switches on the typical Betaflight setup and sometimes you need more than that.
I'm not sure how you could get the momentary switches on the FPV drone controller to fill all those roles. You'd need some kind of flip-flop technology or something like that on the switches, and even then they could only mimic 2-position SPDT switches. And the useability would be very confusing, since there's no way to tell tactilally what state the flip-flopped switch is actually in.
And then there's the whole issue of the transceivers in the new remote, and making them work with the different protocols, frequencies, etc. that the Air Unit/Caddix systems use.
Finally, the Air Unit/Caddix development has ended, as DJI is no longer interested in upgrading the DIY digital system. It's end-of-life and will probably never be updated again. Presumably any more further development of the digital video system is going into the FPV drone (if they haven't orphaned even the FPV drone at this point).
So that'd be a lot of work and risk on DJI's part on a system they're no longer working on or interested in. Even if all that can be done in the controller's firmware, it strikes me as a pretty major project to make it work with full or nearly full functionality with the Air Unit/Caddix system. And not break everything that works with the FPV drone.
So I doubt we'll ever see the new FPV controller work with the Air Unit/Caddix. |
